| 0001483 | FreeCAD | Bug | public | 2014-03-18 18:13 | 2014-12-29 15:48 |
| Reporter | quick61 | Assigned To | wmayer | ||
| Summary | 0001483: Bad Behavior in Part Design After Bug Fix. | ||||
| Description | After implementing fix for bug 1480, another bug was exposed. Forum reference begins in this post - http://forum.freecad.org/viewtopic.php?f=3&t=6103&start=10#p48676 Following the "Steps To Reproduce" below, the delete action now deletes the Pad instead of the line. A second action is required to delete the line along with an action to manually refresh the screen and complete the task. | ||||
| Steps To Reproduce | Open a new sketch, draw a square, close sketch and pad it. Decide to edit sketch so open it again. Sketch is obscured by the pad so go to Model view, select the pad and hit space to hide it. Back to Tasks view, select a line and hit delete. /problem 1 Pad is deleted, and line remains unaffected /end problem 1 Select the line again and hit delete. /problem 2 Line width changes but remains visible and the refresh button must be clicked for the view to be updated. /end problem 2 | ||||
| Additional Information | The current work around is to manually deselect the Pad after hiding it and making sure the sketch is the only selected object in the task view. OS: Ubuntu 13.10 Platform: 64-bit Version: 0.14.3342 (Git) Branch: master Hash: ca6d37202593752c0eeeb1ce56cb4d8c3baf27c0 Python version: 2.7.5+ Qt version: 4.8.4 Coin version: 4.0.0a SoQt version: 1.5.0 OCC version: 6.7.0 | ||||
| 2014-03-18 18:13 | quick61 | New Issue | |
| 2014-12-29 15:47 | wmayer | Note Added: 0005464 | |
| 2014-12-29 15:47 | wmayer | Relationship added | related to 0001838 |
| 2014-12-29 15:48 | wmayer | Status | new => closed |
| 2014-12-29 15:48 | wmayer | Assigned To | => wmayer |
| 2014-12-29 15:48 | wmayer | Resolution | open => fixed |
| 2014-12-29 15:48 | wmayer | Fixed in Version | => 0.15 |
