0001488DraftFeaturepublic2014-05-03 15:46
Reporterteobo Assigned Toyorik
Fixed in Version0.14
Summary0001488: dxf-import is about 10 times faster as svg
DescriptionThe dxf-import is about 10 times faster as svg from same inkscape object.
teobo
2014-03-21 22:10
reporter
1eg_vac_stripped4.svg (126,409 bytes)
yorik
2014-03-27 20:52
administrator   ~0004499
According to the discussion on the forum ( http://forum.freecadweb.org/viewtopic.php?t=6123&p=48847 ), the svg file contains many, many more objects. This is therefore not a bug, but normal.
I think we can close this report, unless someone has another opinion.
2014-03-21 22:10 teobo New Issue
2014-03-21 22:10 teobo File Added: 1eg_vac_stripped4.svg
2014-03-27 20:52 yorik Note Added: 0004499
2014-03-27 20:52 yorik Assigned To => yorik
2014-03-27 20:52 yorik Status new => feedback
2014-03-27 20:52 yorik Project FreeCAD => Draft
2014-05-03 15:46 yorik Status feedback => closed
2014-05-03 15:46 yorik Resolution open => no change required
2014-05-03 15:46 yorik Fixed in Version => 0.14
