| 0001500 | FreeCAD | Bug | public | 2014-04-05 13:10 | 2014-04-16 11:42 |
| Reporter | wandererfan | Assigned To | wandererfan | ||
| Platform | All | OS | All | OS Version | All |
| Target Version | 0.14 | ||||
| Summary | 0001500: Some Draft Tools do not update display | ||||
| Description | see: http://www.forum.freecadweb.org/viewtopic.php?f=10&t=6224 also: http://www.forum.freecadweb.org/viewtopic.php?f=10&t=6174 Need to check each tool and ensure that recompute is called in right place. | ||||
Note to self: behaviour with Draft Primitives is quite different from behaviour with Part Primitives. Part Prims cause recompute during commit, not all Draft Prims do. Recompute inside DraftTools will generally occur before commit, therefore not update display! |
Only Ellipse and Shape2DView are actually missing the recompute(). The other tools are split between recompute() in DraftTools and Draft. Pull request for Ellipse/Shape2DView submitted: http://www.forum.freecadweb.org/viewtopic.php?f=17&t=6337 Should go through Draft/DraftTools and make use of recompute consistent as an aid to future maintainers. |
bugs fixed. Code cleanup to be handled as a separate issue. |
| 2014-04-05 13:10 | wandererfan | New Issue | |
| 2014-04-05 13:10 | wandererfan | Status | new => assigned |
| 2014-04-05 13:10 | wandererfan | Assigned To | => wandererfan |
| 2014-04-05 13:13 | wandererfan | Description Updated | |
| 2014-04-11 00:26 | wandererfan | Note Added: 0004548 | |
| 2014-04-14 21:36 | wandererfan | Note Added: 0004562 | |
| 2014-04-15 10:01 | wandererfan | Note Edited: 0004562 | |
| 2014-04-16 00:44 | yorik | Changeset attached | => FreeCAD Master master 79b8e073 |
| 2014-04-16 11:42 | wandererfan | Note Added: 0004564 | |
| 2014-04-16 11:42 | wandererfan | Status | assigned => closed |
| 2014-04-16 11:42 | wandererfan | Resolution | open => fixed |
