| 0001502 | FreeCAD | Bug | public | 2014-04-07 10:56 | 2014-04-08 15:10 |
| Reporter | Fleder | Assigned To | wmayer | ||
| Platform | PC | OS | Windows | OS Version | 7 64bit |
| Summary | 0001502: crash when using "move" tool in part workbench | ||||
| Description | Hello, i made a custom toolbar consisting of align and move tools from the draft workbench, in my part workbench, so i could move 3d objects around and align them perfectly. i can click on the move tool but if i click on the object afterwards the program always crashes. this happens in the latest developers version of 0.14, no matter if i use 32bit or 64bit FreeCAD. | ||||
| Steps To Reproduce | - go to draft workbench first, then - go to part workbench - create custom toolbar with "move" tool in it - have any object on your workbench - click on move tool - click on object - crash | ||||
| Additional Information | OS: Windows 7 Platform: 32-bit (also tried 64bit because of my OS) Version: 0.14.3343 (Git) Branch: libpack Hash: 8dcb8f68cf17ef152d34d226d7699c98c5bb59fb Python version: 2.7.6 Qt version: 4.8.5 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.7.0 | ||||
And this crash does not happen when using the Move tool when the Draft workbench is active? |
This only happens in Part Workbench, Draft works fine. And only on Windows, i tried it at work with the latest "unstable" build and it worked, too, without a crash. Stable Version 0.13 works fine, too, on Windows in both, Draft and Part WB. |
Sounds very weird. I tried it too but got no crash. Could you please attach the files: + FreeCAD.log (to get this file start FreeCAD with the option --write-log) + crash.dmp Both files are under %APDDATA%\FreeCAD You can copy & paste this as it is into the address bar of the Windows Explorer. |
I uploaded the FreeCAD.log (64bit) and the 32bit file, but could not find any crash.dmp file. Maybe this is because FreeCAD is not crashing but windows tells me it "stopped working" (roughly translated from german, so the actual wording could differ). then i can "kill" the programm or "wait for it to work again" which does nothing. Also, the log files was located in: C:\Users\<Username>\AppData\Roaming\FreeCAD\ i could also upload a video of me, recreating this crash, if this is helpful. |
A video would be cool. But the "stopped working" usually means that there was a crash. |
Here you go: https://www.youtube.com/watch?v=f_SpKESt4BY |
Thanks for the video. With this version FreeCAD 0.14.3310_x64 I could reproduce this crash but not on my Linux box. I still have to check with latest master... Also, it's true that it doesn't create the .dmp file. However, in the Windows Temp folder the system created a file WER1C6A.tmp.hdmp which shows this callstack which gives me a hint where to search: msvcr90.dll!_invalid_parameter() + 0x70 bytes msvcr90.dll!_invalid_parameter_noinfo() + 0x19 bytes > PartGui.pyd!000007fee49da341() [Frames below may be incorrect and/or missing, no symbols loaded for PartGui.pyd] PartGui.pyd!000007fee49da5ea() coin4.dll!0000000001053b3c() coin4.dll!0000000001053b3c() coin4.dll!00000000011251c5() coin4.dll!0000000001045695() coin4.dll!0000000000e01de1() coin4.dll!0000000000f7dd61() coin4.dll!0000000001056f00() coin4.dll!0000000001053b3c() coin4.dll!0000000001053b3c() coin4.dll!0000000001053b3c() coin4.dll!0000000001053b3c() coin4.dll!00000000011251c5() coin4.dll!0000000001045695() coin4.dll!0000000000e01de1() coin4.dll!0000000000f7dd61() coin4.dll!0000000001056f00() coin4.dll!0000000001053b3c() coin4.dll!0000000001053b3c() coin4.dll!0000000001053b3c() coin4.dll!00000000011251c5() coin4.dll!0000000001045695() coin4.dll!0000000000e01de1() coin4.dll!0000000000e115e8() coin4.dll!0000000000e11eca() coin4.dll!0000000000e0fca1() coin4.dll!0000000000e116e7() coin4.dll!0000000000e02392() FreeCADGui.dll!000007feea756307() coin4.dll!000000000100bf00() coin4.dll!000000000100c354() coin4.dll!000000000100cb15() coin4.dll!000000000100ae2e() soqt1.dll!000000000154a64a() soqt1.dll!000000000154b022() FreeCADGui.dll!000007feea717269() soqt1.dll!0000000001554cc9() coin4.dll!0000000000f8fe37() coin4.dll!000000000100b712() coin4.dll!000000000100d3b3() coin4.dll!00000000010c5716() coin4.dll!00000000010c6381() soqt1.dll!0000000001550b87() QtCore4.dll!000000006325ef12() QtCore4.dll!00000000632647b2() QtCore4.dll!000000006325c88c() QtGui4.dll!00000000626e2db2() QtGui4.dll!00000000626e43b6() FreeCADGui.dll!000007feea57ab83() QtCore4.dll!0000000063249591() QtCore4.dll!000000006327200a() QtGui4.dll!00000000626e2db2() QtGui4.dll!00000000626e43b6() FreeCADGui.dll!000007feea57ab83() QtCore4.dll!0000000063249591() QtCore4.dll!000000006324b32f() QtCore4.dll!000000006327251d() user32.dll!UserCallWinProcCheckWow() + 0x11d bytes user32.dll!DispatchMessageWorker() + 0x12a bytes QtCore4.dll!0000000063274755() QtGui4.dll!0000000062747085() QtCore4.dll!000000006324859f() QtCore4.dll!000000006324d360() FreeCADGui.dll!000007feea58de5f() FreeCAD.exe!000000013f6945c2() FreeCAD.exe!000000013f695579() FreeCAD.exe!000000013f694bef() kernel32.dll!0000000076bc652d() ntdll.dll!0000000076dfc541() |
I could confirm this crash also with the latest developer version. However, it has nothing to do with adding the Move command to the Part workbench. This also happens when using it from the Draft workbench. |
If i can help you in any way, let me know. |
It's fixed now. |
| 2014-04-07 10:56 | Fleder | New Issue | |
| 2014-04-07 12:34 | wmayer | Note Added: 0004538 | |
| 2014-04-07 15:42 | Fleder | Note Added: 0004539 | |
| 2014-04-07 15:44 | Fleder | Note Edited: 0004539 | |
| 2014-04-07 16:35 | wmayer | Note Added: 0004540 | |
| 2014-04-07 16:45 | Fleder | File Added: FreeCAD.log | |
| 2014-04-07 16:48 | Fleder | Note Added: 0004541 | |
| 2014-04-07 16:49 | Fleder | Note Edited: 0004541 | |
| 2014-04-07 16:50 | Fleder | Note Edited: 0004541 | |
| 2014-04-07 16:51 | Fleder | File Added: FreeCAD 32bit.log | |
| 2014-04-07 16:52 | Fleder | Note Edited: 0004541 | |
| 2014-04-07 16:59 | wmayer | Note Added: 0004542 | |
| 2014-04-07 17:14 | Fleder | Note Added: 0004543 | |
| 2014-04-08 10:23 | wmayer | Note Added: 0004544 | |
| 2014-04-08 11:58 | wmayer | Note Added: 0004545 | |
| 2014-04-08 13:08 | Fleder | Note Added: 0004546 | |
| 2014-04-08 15:09 | wmayer | Changeset attached | => FreeCAD Master master 78b24c9b |
| 2014-04-08 15:10 | wmayer | Note Added: 0004547 | |
| 2014-04-08 15:10 | wmayer | Status | new => closed |
| 2014-04-08 15:10 | wmayer | Assigned To | => wmayer |
| 2014-04-08 15:10 | wmayer | Resolution | open => fixed |
| 2014-04-08 15:10 | wmayer | Fixed in Version | => 0.14 |
