| 0001503 | FreeCAD | Feature | public | 2014-04-11 06:43 | 2014-04-30 17:11 |
| Reporter | mdinger | Assigned To | wmayer | ||
| OS | Windows | ||||
| Summary | 0001503: Make FreeCAD buildable using QT Creator using windows the VC++ 9 compiler | ||||
| Description | FreeCAD should be buildable with QT Creator. It currently builds fine with the VC++ 9 compiler so that should be targeted first. Currently, it builds fine but almost all the built files are placed one directory too high so it will not run. Example: Correct location: ./file.txt Incorrect: ../file.txt I have a branch where I fixed this issue here but I have only tested it on windows: https://github.com/mdinger/FreeCAD_sf_master/tree/qt_creator_win | ||||
I tried to preserve the previous behavior mostly except for cases like these where the targets change inconsistently: https://github.com/mdinger/FreeCAD_sf_master/commit/1cbd863#diff-5 https://github.com/mdinger/FreeCAD_sf_master/commit/1cbd863#diff-6 https://github.com/mdinger/FreeCAD_sf_master/commit/cf064b6#diff-2 Where the binaries went was inconsistent for non-windows files. Sometimes they went to a "bin" folder, sometimes to a "lib" folder. Sometimes "INSTALL_RPATH" was the same. Sometimes it wasn't. I don't know if it matters or not. I guess I expect it will still run when on non-windows but you might consider the files location important. I don't know. I can make it closer to the way it was if it needs to be but I'm not sure if it needs it. Having someone try to build this in a Linux/Mac environment would probably be good to determine if it still works. In Windows, it compiles slowly because "nmake" is only single threaded. QT includes "jom" which is a wrapper to make "nmake" multi-threaded but it crashes on my machine so I leave it disabled. http://qt-project.org/wiki/jom QT Creator in Windows uses qmake by default but does support cmake. However, it's configuration doesn't seem as flexible because it doesn't support the standard cmake targets: debug, release, etc. |
For the record, this is not specific to Qt Creator, but is a problem with using nmake and the VS compiler. There are somethings that assume the VS IDE is being used. |
Sent pull request here: https://github.com/FreeCAD/FreeCAD_sf_master/pull/22 Thread discussing it here: http://forum.freecadweb.org/viewtopic.php?f=10&t=6297&start=30 It builds fine on Windows for me and is reported to on Linux also. |
FreeCAD: master a17cce35 2014-04-15 03:01:38 mdinger Committer: wmayer Details Diff |
Remove unnecessary quotes. |
Affected Issues 0001503 |
| mod - src/3rdParty/Pivy-0.5/CMakeLists.txt | Diff File | ||
| mod - src/3rdParty/Pivy/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Assembly/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Assembly/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Cam/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Cam/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Complete/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Complete/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Drawing/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Drawing/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Fem/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Fem/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Image/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Image/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Import/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Import/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Inspection/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Inspection/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Mesh/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Mesh/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/MeshPart/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/MeshPart/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Part/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Part/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/PartDesign/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/PartDesign/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Points/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Points/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Raytracing/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Raytracing/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/ReverseEngineering/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/ReverseEngineering/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Robot/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Robot/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Sandbox/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Sandbox/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Sketcher/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Sketcher/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Start/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Start/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Test/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Web/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Web/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Tools/_TEMPLATE_/App/CMakeLists.txt | Diff File | ||
| mod - src/Tools/_TEMPLATE_/Gui/CMakeLists.txt | Diff File | ||
FreeCAD: master 88a3e5bf 2014-04-15 19:07:07 mdinger Committer: wmayer Details Diff |
Add 4th optional parameter to set linux install path |
| mod - cMake/FreeCadMacros.cmake | Diff File | ||
FreeCAD: master 5fbc308c 2014-04-15 23:40:46 mdinger Committer: wmayer Details Diff |
Comment to document why this module alone is installed differently |
FreeCAD: master 1f7743ad 2014-04-17 23:31:16 mdinger Committer: wmayer Details Diff |
Disable null prefix on certain FreeCAD* targets |
FreeCAD: master 8df9289d 2014-04-18 07:16:26 mdinger Committer: wmayer Details Diff |
Add runtime location linux will use |
FreeCAD: master f890d1d1 2014-04-30 05:07:55 mdinger Committer: wmayer Details Diff |
Fix precompiled header build error |
| mod - src/App/CMakeLists.txt | Diff File | ||
| mod - src/Base/CMakeLists.txt | Diff File | ||
| mod - src/Gui/CMakeLists.txt | Diff File | ||
FreeCAD: master 7d427480 2014-04-30 14:07:27 wmayer Details Diff |
+ Fix PCH issue with VS |
FreeCAD: master 1a7cea9b 2014-04-30 18:22:52 Details Diff |
+ Fix prefix of Python extensions built with MinGW |
| mod - src/Main/CMakeLists.txt | Diff File | ||
| 2014-04-11 06:43 | mdinger | New Issue | |
| 2014-04-11 07:21 | mdinger | Note Added: 0004549 | |
| 2014-04-13 04:01 | peterl94 | Note Added: 0004550 | |
| 2014-04-13 04:01 | peterl94 | Note Edited: 0004550 | |
| 2014-04-24 02:33 | mdinger | Note Added: 0004572 | |
| 2014-04-30 17:08 | wmayer | Changeset attached | => FreeCAD Master master f890d1d1 |
| 2014-04-30 17:08 | wmayer | Changeset attached | => FreeCAD Master master 7d427480 |
| 2014-04-30 17:09 | wmayer | Changeset attached | => FreeCAD Master master 1a7cea9b |
| 2014-04-30 17:09 | wmayer | Changeset attached | => FreeCAD Master master 8df9289d |
| 2014-04-30 17:10 | wmayer | Changeset attached | => FreeCAD Master master 1f7743ad |
| 2014-04-30 17:10 | wmayer | Changeset attached | => FreeCAD Master master 5fbc308c |
| 2014-04-30 17:10 | wmayer | Changeset attached | => FreeCAD Master master 88a3e5bf |
| 2014-04-30 17:10 | wmayer | Changeset attached | => FreeCAD Master master a17cce35 |
| 2014-04-30 17:11 | wmayer | Status | new => closed |
| 2014-04-30 17:11 | wmayer | Assigned To | => wmayer |
| 2014-04-30 17:11 | wmayer | Resolution | open => fixed |
| 2014-04-30 17:11 | wmayer | Fixed in Version | => 0.14 |
