| 0001504 | Draft | Feature | public | 2014-04-12 16:54 | 2014-04-17 22:06 |
| Summary | 0001504: Draft Layer object | ||||
| Description | A "layer" object, that works similarily to the autocad layer: - based on DocumentObjectGroupPython - has a LineColor property - has a LineWeight property - has a Printable property (boolean) - propagates the LineColor/LineWeight values to children, when changed - can be used by the Draft DXF exporter & importer - can be used in Drawing pages | ||||
Hi, please do not make the usage of this feature mandatory. I've been working with this feature quite some years before I switched to, the upper class grade cad system to, a well known french cad system. While not implying the french system would be superior, I do underline it takes less effort, and time, to make the same thing in the southern European system compared to the system from the opposite side of the pond, i.e. AutoCad. Using layers do add a lot of extra work for the design engineer as she/he must decide, and act upon, which layer the next command shall be associated with. A smarter way may be to assign some properties like values: width, colour, slope, length, protrusion and so on for each and every feature. Like an arrow or a dimension line. Then ask the user if they would like to use it from now on and in a consecutive manner. Then you'd get the desirable behaviour from this point and onwards. One can always add layers behavior to the default but not force a user to use it. For what ever it's worth, this is my opinion. Reagards/ Pauvres_honteux |
Hi Pauvres_honteux, Thanks for the feedback, Of course it won't be mandatory... Just a convenience tool for who needs it. We rarely do mandatory things here ;) I'll probably also add an option to the DXF import to specify if you want your DXF layers to be imported as Draft layers or not. So you should be totally free to use it or not. The workflow you describe is more or less what happens now in the draft module. |
FreeCAD: master 6f896d8f 2014-04-17 23:18:51 Details Diff |
Draft: Added Layer tool - issue 0001504 |
Affected Issues 0001504 |
| mod - src/Mod/Arch/InitGui.py | Diff File | ||
| mod - src/Mod/Draft/DraftTools.py | Diff File | ||
| mod - src/Mod/Draft/Draft_rc.py | Diff File | ||
| mod - src/Mod/Draft/InitGui.py | Diff File | ||
| mod - src/Mod/Draft/Resources/Draft.qrc | Diff File | ||
| add - src/Mod/Draft/Resources/icons/Draft_Layer.svg | Diff File | ||
| mod - src/Mod/Drawing/App/FeaturePage.cpp | Diff File | ||
FreeCAD: master e2b24d86 2014-04-18 00:02:57 Details Diff |
Draft: DXF in/out now supports Draft Layers - fixes 0001504 |
| mod - src/Mod/Draft/Resources/ui/userprefs-import1.ui | Diff File | ||
| 2014-04-12 16:54 | yorik | New Issue | |
| 2014-04-12 16:54 | yorik | Status | new => assigned |
| 2014-04-12 16:54 | yorik | Assigned To | => yorik |
| 2014-04-12 16:55 | yorik | Description Updated | |
| 2014-04-12 16:55 | yorik | Project | FreeCAD => Draft |
| 2014-04-13 17:01 | Pauvres_honteux | Note Added: 0004557 | |
| 2014-04-13 17:23 | yorik | Note Added: 0004558 | |
| 2014-04-17 21:22 | yorik | Changeset attached | => FreeCAD Master master 6f896d8f |
| 2014-04-17 22:06 | yorik | Changeset attached | => FreeCAD Master master e2b24d86 |
| 2014-04-17 22:06 | yorik | Status | assigned => closed |
| 2014-04-17 22:06 | yorik | Resolution | open => fixed |
