| 0001505 | FreeCAD | Patch | public | 2014-04-13 10:41 | 2014-04-16 13:39 |
| Reporter | nickoe | Assigned To | wmayer | ||
| Platform | Linux | ||||
| Summary | 0001505: Fix multiple bugs in Idf.py | ||||
| Description | When trying to fix the issue in /view.php?id=1366 It was improperly merged, I fix this in this patch. In addition to that I had to fix a path to make the script run succesfully. | ||||
| Steps To Reproduce | Import a IDF file and see that freecad complains in the terminal it was started. | ||||
| related to | 0001424 | closed | emn import failure |
Weird, I have never seen a merge failing so badly: https://github.com/FreeCAD/FreeCAD_sf_master/commit/e1b5f91378114eb993db7aff2c356503d067b9dd |
Me neither, but none the less it happened. I wanted to test the reffered bug out, so I found that I also had to fix the path to footprints_models.csv. |
I see you comitted it. But I see you did not change idflibs to Idflibs. Starting with a capital 'I'. That is what it is named on my system at least. |
It has to be Idflibs, it is also specified as such in the Idf CMakeLists.txt |
> It has to be Idflibs, it is also specified as such in the Idf CMakeLists.txt Oops, sorry I have overlooked this. I thought it was only the moved slash. |
FreeCAD: master be8c5938 2014-04-13 13:55:33 Details Diff |
+ fixes 0001505: Fix multiple bugs in Idf.py |
Affected Issues 0001505 |
| mod - src/Mod/Idf/Idf.py | Diff File | ||
FreeCAD: master e34c0f67 2014-04-13 16:34:14 Details Diff |
| 2014-04-13 10:41 | nickoe | New Issue | |
| 2014-04-13 10:41 | nickoe | File Added: 0001-Fix-multiple-bugs-in-Idf.py.patch | |
| 2014-04-13 10:49 | nickoe | File Added: bm.emn | |
| 2014-04-13 11:08 | nickoe | File Added: example-idf.zip | |
| 2014-04-13 11:51 | wmayer | Note Added: 0004552 | |
| 2014-04-13 11:56 | wmayer | Summary | Fix multibe bugs in Idf.py => Fix multiple bugs in Idf.py |
| 2014-04-13 12:06 | nickoe | Note Added: 0004553 | |
| 2014-04-13 12:18 | wmayer | Changeset attached | => FreeCAD Master master be8c5938 |
| 2014-04-13 12:18 | wmayer | Assigned To | => wmayer |
| 2014-04-13 12:18 | wmayer | Status | new => closed |
| 2014-04-13 12:18 | wmayer | Resolution | open => fixed |
| 2014-04-13 12:25 | nickoe | Note Added: 0004554 | |
| 2014-04-13 12:25 | nickoe | Status | closed => feedback |
| 2014-04-13 12:25 | nickoe | Resolution | fixed => reopened |
| 2014-04-13 12:32 | nickoe | Note Added: 0004555 | |
| 2014-04-13 12:32 | nickoe | Status | feedback => assigned |
| 2014-04-13 14:04 | wmayer | Note Added: 0004556 | |
| 2014-04-13 14:58 | wmayer | Changeset attached | => FreeCAD Master master e34c0f67 |
| 2014-04-13 14:58 | wmayer | Status | assigned => closed |
| 2014-04-14 22:00 | wmayer | Relationship added | related to 0001424 |
