0001506DraftFeaturepublic2014-05-03 15:42
Reporterclifton gordon Assigned Toyorik
Platform64 bitOSWindows 7 OS Versionhome premium
Product Version0.13
Fixed in Version0.14
Summary0001506: can't make a d-spline in draft.
DescriptionWorking on the engine tutorial trying to draw the d-spline on the top of the block. I can click the first few points and then it crashes.
Steps To Reproduceredrew complete tutorial three times and have the same results. This is the engine tutorial with the two cylinder block. I don't know if it is a memory problem or a glitch in the program. I downloaded and reinstalled free cad just to make sure I had a clean download. Same results.
Additional InformationOS: Windows 7
Platform: 32-bit
Version: 0.13.1828
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.3.0
If I didn't do this right please advise.
clifton gordon
2014-04-14 18:52
reporter
motor.FCStd (34,164 bytes)
yorik
2014-04-14 20:16
administrator   ~0004560
Can you try with a newer version? 0.13 is pretty old already, and that bug has probably been fixed already in 0.14...
yorik
2014-05-03 15:42
administrator   ~0004607
I just tried in 0.14, and drawing the spline on top of the engine block works correctly. I'll close this bug report since it seems that the problem is already solved, feel free to reopen if needed.
2014-04-14 18:52 clifton gordon New Issue
2014-04-14 18:52 clifton gordon File Added: motor.FCStd
2014-04-14 20:16 yorik Note Added: 0004560
2014-04-14 20:17 yorik Assigned To => yorik
2014-04-14 20:17 yorik Status new => feedback
2014-05-03 15:42 yorik Note Added: 0004607
2014-05-03 15:42 yorik Status feedback => closed
2014-05-03 15:42 yorik Resolution open => no change required
2014-05-03 15:42 yorik Fixed in Version => 0.14
