| 0000151 | FreeCAD | Feature | public | 2010-09-08 10:13 | 2011-03-29 19:49 |
| Priority | low | Severity | minor | Reproducibility | N/A |
| Summary | 0000151: support 3DFACES in dxf import & export | ||||
| Description | DXF format, althought it is "open", is very closed inrelation with 3D. There are basically 2 possible types of 3D data in a dxf file: 3DFACE entities, which are simple triangles, and ACIS data, which comes as one big block of binary code inside the file. ACIS format is proprietary and undocumented, so its a no-go for us... But it supports solids and all the stuff. Supporting 3DFACE entities is actually not too useful, but it will at least allow to export something. | ||||
added in r4330. 3DFACE entities, 3D polyline meshes and 3D polyface meshes (both special kinds of polylines) are imported respectively as Part faces and meshes. I also added an option in the Draft preferences to allow exporting 3D objects as polyfaces, therefore allowing for more or less decent dxf 3d export. |
| 2010-09-08 10:13 | yorik | New Issue | |
| 2010-09-08 10:15 | yorik | Status | new => assigned |
| 2010-09-08 10:15 | yorik | Assigned To | => yorik |
| 2011-03-14 23:12 | yorik | Relationship added | parent of 0000308 |
| 2011-03-29 19:49 | yorik | Note Added: 0000755 | |
| 2011-03-29 19:49 | yorik | Status | assigned => closed |
| 2011-03-29 19:49 | yorik | Resolution | open => fixed |
| 2011-03-29 19:49 | yorik | Fixed in Version | => 0.12 |
