0001510FreeCADBugpublic2014-04-25 10:57
Reporterteobo Assigned Towandererfan
PrioritylowSeverityminorReproducibilityalways
Summary0001510: Part.Face() does not bore
Description>Now I found:
>viewtopic.php?f=22&t=5376#p43034
>..pass a list of several wires then the first wire is used to create the face and >the further wires describe holes in this face
This does not function. See bug-demo script:
http://forum.freecadweb.org/viewtopic.php?f=22&t=6300#p50587
Workaround:
diff=DWire.Shape.cut(DWire001.Shape)
Part.show(diff)
wandererfan
2014-04-18 12:57
manager
pcb.py (Attachment missing)
wandererfan
2014-04-18 13:03
manager   ~0004568
2D Boolean operation in OCC have a bad reputation. Your work around may cause problems too.
The cut wires in a perforated face should be "reversed". The forum pictures look like all the wires are forward.
Issue 0001331 was similar. See attached pcb.py for an example of making perforated faces using Part.Face.
2014-04-16 17:23 teobo New Issue
2014-04-18 12:57 wandererfan File Added: pcb.py
2014-04-18 13:03 wandererfan Note Added: 0004568
2014-04-18 13:03 wandererfan Assigned To => wandererfan
2014-04-18 13:03 wandererfan Status new => feedback
2014-04-25 10:57 wandererfan Status feedback => closed
2014-04-25 10:57 wandererfan Resolution open => no change required
