| 0001512 | FreeCAD | Bug | public | 2014-04-17 21:04 | 2014-04-23 15:28 |
| Reporter | nahshon | Assigned To | wmayer | ||
| Platform | PC | OS | Fedora Linux | OS Version | 20 (x86_64) |
| Summary | 0001512: After trying to set a bad value, the pad editor does not show | ||||
| Description | In InputField::setToLastUsedValue, if the last value from the history is not a valid quantity, an exception prevents display of the editor. Also an error is written to the console: Exception (Thu Apr 17 22:22:46 2014): syntax error Traceback (most recent call last): File "<string>", line 1, in <module> <type 'exceptions.Exception'>: FreeCAD exception thrown (syntax error) Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> | ||||
| Steps To Reproduce | Create a simple sketch (with any closed shape, eg, a circle). Close the sketcher Press the "Pad" button Type in an invalid value in the Length field and press <enter> delete the pad, keep the sketch and select it... (or use on a new sketch, or even close and restart FreeCAD. The problem status is persistent). Press the "Pad" button Result: A pad was created, but an error message is printed and the editor is not shown. | ||||
| Additional Information | (not tested) The same problem may also exist with other inputs that use the quantity parser. -------------- Work-around: double click on a pad in the model tree view to edit the pad. Insert a valid value and press enter to keep it in the history. --------------- Suggested fix - restore original text (not value) to the input field: in src/Gui/InputField.cpp: void InputField::setToLastUsedValue(void) { std::vector<QString> hist = getHistory(); if(hist.size()>0) this->setText(hist[0]); } | ||||
| 2014-04-17 21:04 | nahshon | New Issue | |
| 2014-04-19 09:50 | wmayer | Status | new => confirmed |
| 2014-04-23 15:28 | wmayer | Changeset attached | => FreeCAD Master master a31ce8e3 |
| 2014-04-23 15:28 | wmayer | Assigned To | => wmayer |
| 2014-04-23 15:28 | wmayer | Status | confirmed => closed |
| 2014-04-23 15:28 | wmayer | Resolution | open => fixed |
