| 0001517 | PartDesign | Bug | public | 2014-04-26 16:37 | 2014-05-03 22:08 |
| Reporter | tempr | Assigned To | wmayer | ||
| Platform | PC | OS | Windows 7 Ultimate | OS Version | SP 1 |
| Summary | 0001517: Problem with constraint menu not displaying properly if moved (overwrites the background) | ||||
| Description | When I moved the constraint menu around it started overwriting the background, check the image in the link below. It seems like a general menu/UI problem i tested it only on horizontal/vertical constraints, and it only appears when you double-click the constraint in the editor, not if you double-click on it in the Tasks/Constraints section in the combo view, or when the menu appears for the first time when you use the command (idk where else could this bug re-appear) Picture on this thread (search for this text) "New bug 1:": http://forum.freecadweb.org/viewtopic.php?f=19&t=6394&start=10 | ||||
| Steps To Reproduce | 1. Create a new file 2. Create a new sketch 3. Create whatever element you want with random dimensions (line for example) 4. Set a vertical/horizontal constraint on one point 5. Double-click on the constraint in the editor to edit it 6. Try to drag the menu around | ||||
| Additional Information | My FreeCAD build info: OS: Windows 7 Platform: 32-bit Version: 0.14.3389 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 I have also tried it on this unofficial build with same results (bug): OS: Windows 7 Platform: 32-bit Version: 0.14.3343 (Git) Branch: libpack Hash: 8dcb8f68cf17ef152d34d226d7699c98c5bb59fb Python version: 2.7.6 Qt version: 4.8.5 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.7.0 | ||||
There is no picture in the linked forum topic. Attaching it here would be more convenient. You talk of "moving the constraint menu". This is a confusion of term. You simply cannot move a menu. You can move a toolbar, or a dialog window, but not a menu. Wikipedia entry on Menu (computing): http://en.wikipedia.org/wiki/Menu_%28computing%29 |
My bad, I brainfarted there. IDK the proper term for it though, I was talking about the window for the input of the constraint data. Can you change the report to fix that? I don't think I have the option to edit it (or I am missing it). Hm, I just opened the topic and it displays for me. OK, here is a direct link to it: http://s12.postimg.org/w0z0fiza3/Menu_bug.jpg |
I cannot confirm this issue. Maybe it's graphic card/driver related. Anyway, the point is that when you open the dialog then the 3d view in the background won't get any paint events. But it's weird that you get different results when double-clicking the task panel item or the element inside the 3d view. |
"Anyway, the point is that when you open the dialog then the 3d view in the background won't get any paint events." Yes and the dialog overwrites the background, it all clears when I exit the dialog though so I would rate this as a cosmetic bug. "But it's weird that you get different results when double-clicking the task panel item or the element inside the 3d view." That is why I still rate it as a bug (FreeCADs or of some library used in FreeCAD). I dismissed it as a driver/GFX card issue because I never had similar problems with any other program I use and because appearance of the problem is, as mentioned, quite selective. Maybe it got fixed in the version you use? Can you try it with an older version (or on another OS)? |
I have checked several older versions and with none of them I have any issues. I also doubt that it's the fault of FreeCAD code because we don't do anything special there but 3rd party libs may do. The involved libs are mainly Qt and Coin3d and maybe in combination with your driver it shows this effect. This may explain why other applications don't show this effect (given that they are not using Qt and/or Coin3d). Btw, my system here is also Win7. |
I have an old WinXP in a virtual box and there I get exactly the same behaviour as you've described. |
FreeCAD: master cb720fae 2014-05-03 23:39:04 Details Diff |
+ fixes 0001517: Problem with constraint menu not displaying properly if moved (overwrites the background) |
Affected Issues 0001517 |
| mod - src/Mod/Sketcher/Gui/EditDatumDialog.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/EditDatumDialog.h | Diff File | ||
| 2014-04-26 16:37 | tempr | New Issue | |
| 2014-04-26 17:33 | normandc | Note Added: 0004578 | |
| 2014-04-26 17:35 | normandc | Note Edited: 0004578 | |
| 2014-04-27 21:16 | tempr | Note Added: 0004590 | |
| 2014-04-29 12:18 | wmayer | Note Added: 0004595 | |
| 2014-05-03 14:18 | tempr | Note Added: 0004605 | |
| 2014-05-03 14:21 | tempr | Note Edited: 0004605 | |
| 2014-05-03 17:31 | wmayer | Note Added: 0004620 | |
| 2014-05-03 17:42 | wmayer | Note Added: 0004621 | |
| 2014-05-03 22:08 | wmayer | Changeset attached | => FreeCAD Master master cb720fae |
| 2014-05-03 22:08 | wmayer | Assigned To | => wmayer |
| 2014-05-03 22:08 | wmayer | Status | new => closed |
| 2014-05-03 22:08 | wmayer | Resolution | open => fixed |
