0001525FreeCADMerge requestpublic2014-05-01 12:16
Reportershoogen Assigned Towmayer
PrioritynormalSeverityminorReproducibilityN/A
Status closedResolutionfixed
Product Versiontrunk
Target Version0.14Fixed in Version0.14
Summary0001525: use transformShape for uniform scaling in Draft._Clone Feature
DescriptionThe following changes since commit 66de74d14a59a4a8b23a163a737a3bd2472f2685:
  + Remove redefinition of /EHa which causes warnings with QtCreator (2014-04-30 19:21:49 +0200)
are available in the git repository at:
  git://github.com/5263/FreeCAD dev-clone-uniform-scaling
for you to fetch changes up to 8dca9210d8422541488e1931491c2bdd192777f8:
  use transformShape for uniform scaling in Draft._Clone Feature (2014-05-01 11:59:56 +0200)
      add support for Draft.Clone in exportDRAWEXE
 src/Mod/Draft/Draft.py | 6 ++++-
 src/Mod/OpenSCAD/CMakeLists.txt | 1 +
 src/Mod/OpenSCAD/exportDRAWEXE.py | 48 +++++++++++++++++++++++++++++++++++++
 3 files changed, 54 insertions(+), 1 deletion(-)
Additional Informationhttp://forum.freecad.org/viewtopic.php?f=3&t=6472&p=52217#p52215
http://tracker.dev.opencascade.org/view.php?id=24890
2014-05-01 11:07
administrator   ~0004598
git show 8dca921
Related Changesets
FreeCAD: master 8dca9210
2014-05-01 11:58:09
shoogen
Details Diff
use transformShape for uniform scaling in Draft._Clone Feature Affected Issues
0001525
mod - src/Mod/Draft/Draft.py Diff File
2014-05-01 10:10 shoogen New Issue
2014-05-01 11:07 wmayer Note Added: 0004598
2014-05-01 11:07 wmayer Status new => closed
2014-05-01 11:07 wmayer Assigned To => wmayer
2014-05-01 11:07 wmayer Resolution open => fixed
2014-05-01 11:07 wmayer Fixed in Version => 0.14
2014-05-01 12:16 wmayer Changeset attached => FreeCAD Master master 8dca9210
