| 0001531 | FreeCAD | Merge request | public | 2014-05-03 16:18 | 2014-05-03 17:21 |
| Reporter | tanderson69 | Assigned To | wmayer | ||
| Priority | low | Severity | trivial | Reproducibility | N/A |
| Platform | amd64 | OS | Kubuntu | OS Version | 13.10 |
| Target Version | trunk | Fixed in Version | 0.14 | ||
| Summary | 0001531: Option for new check in part check geometry | ||||
| Description | I added an additional geometry check(BOPAlgo_ArgumentAnalyzer) for the part check geometry command. This new check isn't giving us much benefit if any. It reports errors on solids that seem to work fine with boolean ops. It is also really slow. I have made a change that looks for a parameter before running this new check. Parameter defaults to "false"(check won't be run). The user can still edit config file to turn it back on if wanted. to get this patch. //assuming origin is sourceforge git fetch origin d7d387eaa70ad9ea1a2ebf2b8e9aa4c1f986f5bf && git cherry-pick d7d387eaa70ad9ea1a2ebf2b8e9aa4c1f986f5bf | ||||
> git fetch origin d7d387eaa70ad9ea1a2ebf2b8e9aa4c1f986f5bf Doesn't work. It gives the errors: > fatal: Couldn't find remote ref d7d387eaa70ad9ea1a2ebf2b8e9aa4c1f986f5bf > fatal: The remote end hung up unexpectedly Are you sure about the hash value? Can I simply merge the branch "tanderson-part-checkGeometry" instead? |
whoops. That hash was from another branch here. Sorry. fixed: //assuming origin is sourceforge git fetch origin 4d225f771fb2011bb81f2d4ec9e255697e3bc400 && git cherry-pick 4d225f771fb2011bb81f2d4ec9e255697e3bc400 But, yes in this case you could merge it. My master here isn't up to date. so you will probably end up with a merge commit, which is why I went with the cherry pick. Thanks. |
The hash is correct now but "git fetch origin ..." still gives the same error. So, I checked older pull requests and there it was only a "git cherry-pick ..." to run and this indeed does the trick. Maybe it's because I did a git pull before? |
| 2014-05-03 16:18 | tanderson69 | New Issue | |
| 2014-05-03 16:18 | tanderson69 | Status | new => assigned |
| 2014-05-03 16:18 | tanderson69 | Assigned To | => wmayer |
| 2014-05-03 16:46 | wmayer | Note Added: 0004617 | |
| 2014-05-03 16:53 | tanderson69 | Note Added: 0004618 | |
| 2014-05-03 17:20 | wmayer | Note Added: 0004619 | |
| 2014-05-03 17:21 | wmayer | Status | assigned => closed |
| 2014-05-03 17:21 | wmayer | Resolution | open => fixed |
| 2014-05-03 17:21 | wmayer | Fixed in Version | => 0.14 |
