| 0001542 | FreeCAD | Bug | public | 2014-05-12 01:05 | 2014-05-14 14:18 |
| Reporter | LambdaTheUltimate | Assigned To | wmayer | ||
| OS | Win | OS Version | 7 | ||
| Summary | 0001542: 4 empty / blank buttons - Customize / Toolbars Tab / Move buttons (right,left,up,down) missing icons | ||||
| Description | Version 0.14 there are 4 empty / blank buttons (i.e. missing images / icons). On 'Toolbars Tab' (between the two list panes) during Toolbar Customization. Tool Tips work. | ||||
| Steps To Reproduce | Right-Click a Toolbar, click 'Customize', select 'Toolbars Tab'. Buttons between 2 list panes are blank. | ||||
| Additional Information | Users (as I did) can guess what the buttons do (Windows Toolbar customization is fairly standard across many Windows applications). Tool Tips work and help. | ||||
As version you said you use "trunk". So you are compiling from sources then? What is your current version number? And more important which version of Qt do you use ATM? |
'Unstable' release Windows 0.14 3389 32-bit (seems pretty stable) Qt is showing under Help | 'About QT' as 4.5.2 I selected 'Trunk' in bug report as '0.14' I think was not an option (I remember seeing 0.14 somewhere else, maybe as an option for bug filtering) |
Qt 4.5 is known to render certain SVG images incorrectly. Anyway I still have Qt 4.5.3 here and check how it behaves... |
| 2014-05-12 01:05 | LambdaTheUltimate | New Issue | |
| 2014-05-12 12:39 | wmayer | Note Added: 0004658 | |
| 2014-05-13 19:21 | LambdaTheUltimate | Note Added: 0004671 | |
| 2014-05-14 09:34 | wmayer | Note Added: 0004673 | |
| 2014-05-14 14:18 | wmayer | Changeset attached | => FreeCAD Master master 9e5ed987 |
| 2014-05-14 14:18 | wmayer | Assigned To | => wmayer |
| 2014-05-14 14:18 | wmayer | Status | new => closed |
| 2014-05-14 14:18 | wmayer | Resolution | open => fixed |
