| 0001551 | Arch | Feature | public | 2014-05-17 15:13 | 2015-04-27 14:11 |
| Summary | 0001551: Arch - Advanced IFC support | ||||
| Description | Features needed to the IFC importer/exporter * Import 01 Retrieve the base polyline of extrusions 02 Retrieve the axis of walls 03 Retrieve the colors 04 Retrieve groups * Export 05 Export extruded ellipses 06 Export extruded composite curves (lines + arcs) 07 Separate openings 08 Separate boolean additions 09 Support groups 10 Export axes of walls | ||||
05 is done |
06 and 07 are done |
Add: 11 Add a property to Arch objects to allow to force export as Brep |
08 and 11 are done Add: 12 Support import of IfcAnnotations containing 2D data (lines, etc). |
This is now all implemented, except wall axes, but it is apparently not used by any other app... |
| 2014-05-17 15:13 | yorik | New Issue | |
| 2014-05-17 15:13 | yorik | Status | new => assigned |
| 2014-05-17 15:13 | yorik | Assigned To | => yorik |
| 2014-05-29 20:30 | yorik | Description Updated | |
| 2014-05-29 20:31 | yorik | Description Updated | |
| 2014-05-29 20:32 | yorik | Description Updated | |
| 2014-05-29 20:32 | yorik | Note Added: 0004729 | |
| 2014-06-15 16:56 | yorik | Note Added: 0004752 | |
| 2014-07-06 15:22 | yorik | Project | FreeCAD => Arch |
| 2014-07-06 15:26 | yorik | Target Version | => 0.15 |
| 2014-07-07 21:50 | yorik | Note Added: 0004777 | |
| 2014-09-14 15:56 | yorik | Note Added: 0005100 | |
| 2015-01-21 17:55 | yorik | Target Version | 0.15 => |
| 2015-04-27 14:10 | yorik | Note Added: 0006091 | |
| 2015-04-27 14:11 | yorik | Status | assigned => closed |
| 2015-04-27 14:11 | yorik | Resolution | open => fixed |
| 2015-04-27 14:11 | yorik | Fixed in Version | => 0.16 |
