| 0001552 | FreeCAD | Bug | public | 2014-05-17 18:01 | 2014-08-05 09:36 |
| Reporter | ulrich1a | Assigned To | |||
| Summary | 0001552: Sketcher lines on construction lines are not selectable | ||||
| Description | Sometimes it is useful to have a normal line on top of a construction line in the Sketcher. But the normal line is not selectable. | ||||
| related to | 0000693 | closed | Sketcher | Sketcher: No GUI to select overlapping lines in sketches |
Forum topic is located here: http://forum.freecadweb.org/viewtopic.php?f=3&t=6496 IMO this is a duplicate of bug 0000693 but I'll let the devs decide. |
FreeCAD: master 1011dd41 2014-08-04 17:36:22 Details Diff |
Squashed commit of the following: commit 695becbbfff961b13e3edb5a4e1e4487bc53b4bb Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Mon Aug 4 15:24:33 2014 +0200 - Making combo disable state. - Updating Art (Thanks Jim!) commit d5391d40ace450fa2e65fe2b4ab8029ad37cacf8 Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Fri Aug 1 00:40:15 2014 +0200 - Adaptation of code to Workbench's new Template structure. - Minor adaptation of new ViewProvideSketch code to new constraint code (only in code extensions needed for element Widget) commit ecdec20afa33c9a950e6054e80e4aa9c72aad8b6 Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Thu Jul 31 15:31:38 2014 +0200 Fix so that when applying a coincident constraint to a plurality of points, if one constraint on a couple of points exists, no new coincident constraint is added to this couple. Fixes: http://forum.freecadweb.org/viewtopic.php?f=3&t=6890 commit 32ef59d76e6c63356f5d36598ca11eb47c2e52af Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Thu Jul 31 14:13:58 2014 +0200 Add some placeholder art for icons to avoid having a cross icon and annoying icon not found messages. commit ccb60a3a7e71a0eb8ad5d896542314a98ef314a8 Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Mon Jul 28 20:15:29 2014 +0200 - Fixed Length Constraint accelerator (D) to SHIFT+D to avoid colision with other higher level FreeCAD accelerator assignment. - Selection Accelerators now toggle on shortcut execution, and act when no other element is selected (fixed bug) TODO: Art+Toolbar commit 791358d046e8eeb03fa00272f5627c75254c48eb Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Mon Jul 28 15:12:07 2014 +0200 Fixing shortcut system: - Take shortcuts automatically from CommandManager. - Fixed two shortcuts in CommandConstraints (Point on Object - O and Parallel Constraint - P to SHIFT+O and SHIFT+P to avoid collision with other constraints) - Fixed shortcuts in CommandConstraintAccel to non-already-existing combinations - Fixed Sketcher Menu to show accelerators commit 12d366406a45038ce1a4f725a98e4f570475084b Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Mon Jul 28 11:53:37 2014 +0200 Implemented SHIFT multiple selection functionality in listwidget. commit 0606ea7dfe38fdf8924f65f14382f1b327145c80 Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Mon Jul 28 11:02:02 2014 +0200 Added Sketcher Accelerators for: - Selection of H Axis - V Axis - Origin Main TODO: Shortcuts and Shift in list widget implementation commit 297464807fc56fbcf31efadff9625fc05bb20c41 Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Wed Jul 23 11:37:21 2014 +0200 Implementation of: - Switch on 'Z' instead of 'Shift' - Checkbox to select whether element internal name (e.g. Edge10) should be presented on list or not (Sponssi requested) - Checkbox to force going back to "Edge" type on change from one element to the next (Sponssi requested) commit c8764b116acdcfdc7ef7658dc6009fb8db807906 Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Wed Jul 23 07:57:11 2014 +0200 TaskSketcher Elements: - Store Vertex within elements for optimization (reduce loops searching for vertex in every function call) - Added the accelerators described below + Toggle Construction as context menu commands - Fixed bug (Thanks sponssi!): After some element has been preselected from the list and the cursor moved to the drawing area, the preselection doesn't seem to be resetted in the widget or whereever it is handled. Tapping shift still swaps the preselection between the points of the previously selected element. The left mouse button has to be clicked in the draw area to get rid of this. http://forum.freecadweb.org/viewtopic.php?f=10&t=6861&sid=7eea4adc7ecf4cebd561b357601866a2&start=20 - Extended naming of elements, to facilitate writing python code (as requested by sponssi). - Minor modifications (creation of utility fuctions, code readibility, ...) Sketcher Workbench: - First effort to add a toolbar with the accelerators. Sketcher Accelerators: (Perform actions on existing elements, as opposed to Geometry Creation, not restricted to applying constraints) - Close Shape : of selected edges (i.e. lines and arcs) - Connect : selected edges (connect endpoint edge with starting point of next edge according to selection order) - Select Constraints : associated with currently selected edges commit 1dc18204a4e2e38f71d729a7692383f50a7d4654 Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Sat Jul 12 16:06:48 2014 +0200 New alternative implementation of the Sketch Element List. This version comprises: - Identification via icon of type of geometric element (Point, Arc, Line, Circle) and Type of selection (Edge, Starting Point, End Point, Center Point) - Corrected a bug where upon selection from the combobox, the icons were not updated (Thanks Jim!) - Implementation of jump to next valid type of last preselected element (aka fast-forward) for all the types. commit 4d472ef796362405c3982355f86489fa92cbfe6d Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Thu Jun 26 17:15:51 2014 +0200 Feature request by jmaustpc - When an object does not have an element, lets put a different icon. - Currently the constraint lock icon is used until availability of a new one. commit 6d15478f6533ff3805520a8ca36d1c41908cb0af Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Thu Jun 26 14:54:23 2014 +0200 Bug fix (preselection not disappearing on changing element without the element Type). commit e33043e17781fcf6399257696f115f68ab4580ec Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Thu Jun 26 14:39:20 2014 +0200 New nicer icons by jmaustpc. They look much nicer :-) commit 2ce2d6ff1ad2d81b0b1e30ffcbe9f2cc445f2e5b Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Thu Jun 26 14:37:21 2014 +0200 Fast-Forward functionality: - If an element not having "midpoint" is preselected, then on pressing SHIFT the Type will jump from EndPoint to Line skipping midpoint. - This is intended as a productivity feature, as most sketch elements usually are lines commit 1865d06d06582a49da10ddc123133807a4593060 Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Wed Jun 25 15:47:22 2014 +0200 Bug fix (thanks jmaustpc) - Preselection is maintained even though the geometric element does not have the "Type". - Fix involves calling for remove preselection in TaskSketcherElement - Implementing the response to the message RmvPreselection in ViewProviderSketch commit 14e21da4b4ed0e9a2b3e846a4e51f6745d5e0ab7 Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Mon Jun 23 14:25:35 2014 +0200 Fix Bug with null pointer (thanks jmaustpc!) Clean up code commit 0d99eb633f1bca45d4e7bb22c57bd4892767a390 Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com> Date: Wed Jun 11 16:32:48 2014 +0200 New widget for the Taskbar of the Sketcher WB. The objectives of this widget are: 1. Allow editing of sketches when they have (partially) overlapping lines of any type (construction/external/normal). 2. Allow the construction of sketches using the keyboard (less mouse intensive) The widget works as follows: 1. A QListWidget presents a list of elements, element is here a geometric element formed Types edges, starting points, end points and midpoints (e.g. circles, arcs) 2. On hovering/Entering one item in the list, it is preselected for easy identification. 3. The selection can be switched from one type to another using the SHIFT key (press and release) in a round-robin fashion (or you can select it using the droplist) 4. Selection of different types is possible (e.g. two points and a line). 5. The contextual menu accessible by right click allow to apply a constraint to the selection. 6. The constraints in the contextual menu have shortcuts, so you can actually use the shortcut directly from the QListWidget. Additional features introduced to other parts during development... - New color introduced for Types that are selected and preselected at the same time - Edges is a SoLineSet. You can not apply many So modifiers (width,offset) to parts of a SoLineSet. An edge part of a SoLineSet that is drawn after another one, covers it unless it is closer to the camera. The system of manual offsets already in place for points has been extended to properly handle (i.e. show) overlapping lines part of a SoLineSet. |
Affected Issues 0000693, 0000930, 0001552 |
| mod - src/Mod/Sketcher/Gui/AppSketcherGui.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Sketcher/Gui/CommandConstraints.cpp | Diff File | ||
| add - src/Mod/Sketcher/Gui/CommandSketcherAccel.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/Makefile.am | Diff File | ||
| mod - src/Mod/Sketcher/Gui/Resources/Makefile.am | Diff File | ||
| mod - src/Mod/Sketcher/Gui/Resources/Sketcher.qrc | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_CloseShape.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_ConnectLines.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_Arc_Edge.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_Arc_EndPoint.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_Arc_MidPoint.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_Arc_StartingPoint.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_Circle_Edge.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_Circle_MidPoint.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_Line_Edge.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_Line_EndPoint.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_Line_StartingPoint.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_Point_StartingPoint.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_Element_SelectionTypeInvalid.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_SelectConstraints.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_SelectHorizontalAxis.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_SelectOrigin.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/Sketcher_SelectVerticalAxis.svg | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_CloseShape.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_ConnectLines.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_Arc_Edge_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_Arc_EndPoint_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_Arc_MidPoint_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_Arc_StartingPoint_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_Circle_Edge_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_Circle_MidPoint_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_Line_Edge_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_Line_EndPoint_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_Line_StartingPoint_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_Point_StartingPoint_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_Element_SelectionTypeInvalid_sm.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_SelectConstraints.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_SelectHorizontalAxis.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_SelectOrigin.xpm | Diff File | ||
| add - src/Mod/Sketcher/Gui/Resources/icons/small/Sketcher_SelectVerticalAxis.xpm | Diff File | ||
| mod - src/Mod/Sketcher/Gui/TaskDlgEditSketch.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/TaskDlgEditSketch.h | Diff File | ||
| add - src/Mod/Sketcher/Gui/TaskSketcherElements.cpp | Diff File | ||
| add - src/Mod/Sketcher/Gui/TaskSketcherElements.h | Diff File | ||
| add - src/Mod/Sketcher/Gui/TaskSketcherElements.ui | Diff File | ||
| mod - src/Mod/Sketcher/Gui/ViewProviderSketch.h | Diff File | ||
| mod - src/Mod/Sketcher/Gui/Workbench.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/Workbench.h | Diff File | ||
| 2014-05-17 18:01 | ulrich1a | New Issue | |
| 2014-05-17 18:55 | normandc | Note Added: 0004685 | |
| 2014-05-17 18:55 | normandc | Note Edited: 0004685 | |
| 2014-05-20 13:40 | wmayer | Relationship added | related to 0000693 |
| 2014-08-05 09:36 | wmayer | Changeset attached | => FreeCAD Master master 1011dd41 |
| 2014-08-05 09:36 | wmayer | Status | new => closed |
| 2014-08-05 09:36 | wmayer | Resolution | open => fixed |
| 2014-08-05 09:36 | wmayer | Fixed in Version | => 0.15 |
