| 0001553 | FreeCAD | Bug | public | 2014-05-18 16:45 | 2015-01-10 11:40 |
| Reporter | Ian | Assigned To | wmayer | ||
| Platform | 32-bit | OS | Windows 7 | OS Version | 32bit |
| Summary | 0001553: printing drawing full size (1:1) prints wrong size | ||||
| Description | When printing drawings 1:1 the drawings are printed incorrect size | ||||
| Steps To Reproduce | Create drawing scale 1:1 print drawing measure drawing sizes do not match | ||||
| Additional Information | Tried borderless, no margins etc. nothing works. I have always been able to print correctly from solid works. | ||||
| Tags | drawing, printing, Qt | ||||
Please provide your FreeCAD version number. |
version 0.14 revision 3389 |
Changing paper size also changes scale this should not happen |
Does this problem only affect the QtPrinting dialog or does the problem also occur when you save the drawing to an .svg file and print the file with a suitable application (like inkscape)? |
Installed inkscape and printed the .svg file it appears spot on as far as I can measure with my digital vernier. |
This is an old problem that has never been solved in FreeCAD AFAIK... But changing the paper size should not change the scale of the views. |
The scaling as reported in 0000932 is fixed now. > But changing the paper size should not change the scale of the views. Really? Assuming you have an A3 drawing but only a printer for A4 why shouldn't it be allowed to scale down the drawing? As long as you select the same paper size in the printer settings as you use for the drawing everything should be fine. There is now a check that verifies orientation and page size and in case it differs a message box pops up asking the user how to continue. |
| 2014-05-18 16:45 | Ian | New Issue | |
| 2014-05-18 16:48 | shoogen | Note Added: 0004691 | |
| 2014-05-19 07:31 | Ian | Note Added: 0004695 | |
| 2014-05-21 08:30 | Ian | Note Added: 0004716 | |
| 2014-05-21 12:20 | shoogen | Note Added: 0004717 | |
| 2014-05-21 12:20 | shoogen | Tag Attached: Qt | |
| 2014-05-21 20:28 | Ian | Note Added: 0004718 | |
| 2014-05-21 20:36 | shoogen | Tag Attached: drawing | |
| 2014-05-21 20:39 | shoogen | Relationship added | related to 0000932 |
| 2014-05-21 20:43 | shoogen | Tag Attached: printing | |
| 2014-05-22 01:30 | normandc | Note Added: 0004719 | |
| 2015-01-09 23:37 | wmayer | Note Added: 0005604 | |
| 2015-01-10 11:40 | wmayer | Changeset attached | => FreeCAD Master master 396e9c93 |
| 2015-01-10 11:40 | wmayer | Assigned To | => wmayer |
| 2015-01-10 11:40 | wmayer | Status | new => closed |
| 2015-01-10 11:40 | wmayer | Resolution | open => fixed |
