| 0001564 | FreeCAD | Feature | public | 2014-05-24 16:22 | 2014-08-08 01:40 |
| Target Version | 0.15 | Fixed in Version | 0.15 | ||
| Summary | 0001564: Add python function for GUI verison of Command::doCommand | ||||
| Description | Add python function for GUI verison of Command::doCommand | ||||
http://forum.freecad.org/viewtopic.php?f=22&t=6691&p=54792#p54792 And would like to add that even more importantly the workplane dialog needed a docommand print out, - as often during the work with the gui crashes and then one had ad least fixed the procedure by scripting. And it makes the work easy and controlled, if one can assign - on the fly - a defined workplane. |
| 2014-05-24 16:22 | yorik | New Issue | |
| 2014-05-24 16:22 | yorik | Status | new => assigned |
| 2014-05-24 16:22 | yorik | Assigned To | => yorik |
| 2014-06-05 09:38 | teobo | Note Added: 0004732 | |
| 2014-07-06 15:27 | yorik | Target Version | => 0.15 |
| 2014-08-05 23:02 | yorik | Changeset attached | => FreeCAD Master master 81e983b6 |
| 2014-08-05 23:02 | yorik | Status | assigned => closed |
| 2014-08-05 23:02 | yorik | Resolution | open => fixed |
| 2014-08-08 01:40 | yorik | Fixed in Version | => 0.15 |
