| 0001572 | Arch | Bug | public | 2014-06-05 18:32 | 2014-08-05 21:51 |
| Target Version | 0.15 | Fixed in Version | 0.15 | ||
| Summary | 0001572: Arch Survey tool doesn't respect unit choice | ||||
| Description | Units should be displayed according to preferences | ||||
Aditionally, solve the compound with no center of mass problem http://forum.freecadweb.org/viewtopic.php?f=9&t=5659&p=54886#p54886 |
Commit 92a565f6 solves this on the Arch module side, but the m/s/kg units scheme of FreeCAD still shows areas and volumes in square/cubic millimeters. |
Now everything works according to the units schema. |
FreeCAD: master 92a565f6 2014-06-07 17:09:58 Details Diff |
Arch: Misc fixes * Allow to export subtractions as separate elements in IFC * Fixed Survey tool * Removed unused Arch preferences |
Affected Issues 0001572 |
| mod - src/Mod/Arch/ArchCommands.py | Diff File | ||
| mod - src/Mod/Arch/Arch_rc.py | Diff File | ||
| mod - src/Mod/Arch/Resources/ui/archprefs-import.ui | Diff File | ||
| mod - src/Mod/Arch/ifcWriter.py | Diff File | ||
| mod - src/Mod/Arch/importIFC.py | Diff File | ||
FreeCAD: master 62e9b608 2014-08-05 00:16:10 Details Diff |
Added a couple of missing units in MKS schema |
| mod - src/Base/UnitsSchemaMKS.cpp | Diff File | ||
| 2014-06-05 18:32 | yorik | New Issue | |
| 2014-06-05 18:32 | yorik | Status | new => assigned |
| 2014-06-05 18:32 | yorik | Assigned To | => yorik |
| 2014-06-05 18:32 | yorik | Project | FreeCAD => Arch |
| 2014-06-06 22:32 | yorik | Note Added: 0004739 | |
| 2014-06-07 19:28 | yorik | Changeset attached | => FreeCAD Master master 92a565f6 |
| 2014-06-07 19:29 | yorik | Note Added: 0004742 | |
| 2014-07-06 15:26 | yorik | Target Version | => 0.15 |
| 2014-08-05 21:50 | yorik | Changeset attached | => FreeCAD Master master 62e9b608 |
| 2014-08-05 21:51 | yorik | Note Added: 0004922 | |
| 2014-08-05 21:51 | yorik | Status | assigned => closed |
| 2014-08-05 21:51 | yorik | Resolution | open => fixed |
| 2014-08-05 21:51 | yorik | Fixed in Version | => 0.15 |
