| 0001578 | FreeCAD | Bug | public | 2014-06-08 10:47 | 2014-07-20 16:17 |
| Reporter | petebachant | Assigned To | yorik | ||
| Target Version | 0.15 | Fixed in Version | 0.15 | ||
| Summary | 0001578: Wiki: Cannot create account or log in | ||||
| Description | I am having trouble creating an account on the wiki by signing in with Google. I have also tried WordPress to no avail. | ||||
Creating an account with OpenID doesn't work at the moment, I still couldn't figure out why. But linking an existing wiki accound with an openID works. I'd like to change the "login/create account with openID" to only "login with OpenID", though. |
In the meanwhile please contact one of the forum admins to get an account. You will need to register. http://forum.freecadweb.org/viewtopic.php?f=21&t=6830 |
There is apparently no way to let people to only login with OpenID, not create an account. Since apparently nobody is using OpenID anyway (and it is of little use since none of the other freecad webapps use it), I disabled the OpenID extension, which anyway was a bit buggy and hard to configure correctly. If someone complains, I'll reactivate it... |
| 2014-06-08 10:47 | petebachant | New Issue | |
| 2014-06-08 16:46 | yorik | Note Added: 0004746 | |
| 2014-06-08 16:46 | yorik | Assigned To | => yorik |
| 2014-06-08 16:46 | yorik | Status | new => assigned |
| 2014-07-06 15:27 | yorik | Target Version | => 0.15 |
| 2014-07-17 04:36 | normandc | Note Added: 0004807 | |
| 2014-07-20 16:17 | yorik | Note Added: 0004819 | |
| 2014-07-20 16:17 | yorik | Status | assigned => closed |
| 2014-07-20 16:17 | yorik | Resolution | open => fixed |
| 2014-07-20 16:17 | yorik | Fixed in Version | => 0.15 |
