| 0001583 | File formats | public | 2014-06-17 19:00 | 2014-06-17 22:07 | |
| Reporter | etojpi | Assigned To | yorik | ||
| Summary | 0001583: Import DXF failure | ||||
| Description | The DXF import library fails to load a certain DXF file. Report view: Draft workbench activated DXF libraries not found. Downloading... downloading https://raw.github.com/yorikvanhavre/Draft-dxf-importer/master/dxfColorMap.py ... downloading https://raw.github.com/yorikvanhavre/Draft-dxf-importer/master/dxfImportObjects.py ... downloading https://raw.github.com/yorikvanhavre/Draft-dxf-importer/master/dxfLibrary.py ... downloading https://raw.github.com/yorikvanhavre/Draft-dxf-importer/master/dxfReader.py ... opening /home/user/Documents/b2x0_enclosure/B210_PLATE_REV1.2_101113 NER.dxf... Traceback (most recent call last): File "<string>", line 1, in <module> File "/usr/lib/freecad/Mod/Draft/importDXF.py", line 1318, in open processdxf(doc,filename) File "/usr/lib/freecad/Mod/Draft/importDXF.py", line 880, in processdxf drawing = dxfReader.readDXF(filename) File "/home/user/.FreeCAD/dxfReader.py", line 375, in readDXF obj.data = objectify(obj.data) File "/home/user/.FreeCAD/dxfImportObjects.py", line 1312, in objectify objects.append(type_map[item.type](item)) File "/home/user/.FreeCAD/dxfImportObjects.py", line 938, in __init__ discard, self.layer, discard_index = get_layer(obj.data) File "/home/user/.FreeCAD/dxfImportObjects.py", line 1278, in get_layer if item[0] == 8: <type 'exceptions.AttributeError'>: Object instance has no attribute '__getitem__' | ||||
| Steps To Reproduce | 1) Go to Draft workbench 2) Open file: "B210_PLATE_REV1.2_101113 NER.dxf" 3) Import fails | ||||
| Additional Information | DXF file is attached. FreeCAD info: OS: Ubuntu 14.04 LTS Platform: 64-bit Version: 0.14.2935 (Git) Branch: master Hash: eab159b6ee675012bf79de838c206a311e911d85 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 | ||||
| 2014-06-17 19:00 | etojpi | New Issue | |
| 2014-06-17 19:10 | etojpi | Note Added: 0004754 | |
| 2014-06-17 22:07 | yorik | Relationship added | duplicate of 0001584 |
| 2014-06-17 22:07 | yorik | Status | new => closed |
| 2014-06-17 22:07 | yorik | Assigned To | => yorik |
| 2014-06-17 22:07 | yorik | Resolution | open => duplicate |
