| 0001598 | Draft | Feature | public | 2014-07-08 03:40 | 2015-01-19 16:19 |
| Summary | 0001598: Draft - Cleanup the trimex tool | ||||
| Description | - Allow to select 2 objects and make an auto intersection - Cleanup the task panel + snapper, if CTRL not pressed, switch to select mode - Allow to trim/extend against itself | ||||
FreeCAD: master a91fcc68 2015-01-19 16:49:33 Details Diff |
Draft: Improvements to Trimex tool - fixes 0001598 * Autotrim 2 intersecting draft lines, wires or arcs * Don't snap if CTRL is not pressed * Allow to trim/extend against itself |
Affected Issues 0001598, 0001687 |
| mod - src/Mod/Draft/DraftTools.py | Diff File | ||
| mod - src/Mod/Draft/DraftTrackers.py | Diff File | ||
| mod - src/Mod/Draft/DraftVecUtils.py | Diff File | ||
| 2014-07-08 03:40 | yorik | New Issue | |
| 2014-07-08 03:40 | yorik | Status | new => assigned |
| 2014-07-08 03:40 | yorik | Assigned To | => yorik |
| 2014-07-08 03:40 | yorik | Project | FreeCAD => Draft |
| 2014-09-21 22:45 | yorik | Category | Merge request => Feature |
| 2015-01-19 15:49 | yorik | Description Updated | |
| 2015-01-19 15:56 | yorik | Relationship added | parent of 0001687 |
| 2015-01-19 16:19 | yorik | Changeset attached | => FreeCAD Master master a91fcc68 |
| 2015-01-19 16:19 | yorik | Status | assigned => closed |
| 2015-01-19 16:19 | yorik | Resolution | open => fixed |
