0001600FreeCADBugpublic2014-09-22 13:23
Reportermaxiecool2 Assigned To
PlatformlinuxOSubuntuOS Versionsaucy salamander
Product Version0.14
Summary0001600: constantly crashing while general using
Descriptionexploring freecad with a project i downloaded
the most recent attempt, i was trying to set the dimensions for one part of the project, thats when it crashed, but it has crashed while setting up a drawing. due to the frequency of it crashing i loaded it with strace running. i hope this information helps
Steps To Reproduceunfortunately it has been random
Additional Informationlast bit of strace
recvmsg(6, 0xbffe1644, 0) = -1 EAGAIN (Resource temporarily unavailable)
clock_gettime(CLOCK_MONOTONIC, {346883, 413850499}) = 0
clock_gettime(CLOCK_MONOTONIC, {346883, 413972996}) = 0
write(3, "\1\0\0\0\0\0\0\0", 8) = 8
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x10} ---
rt_sigprocmask(SIG_UNBLOCK, [SEGV], NULL, 8) = 0
write(1, "\33[1;31m*** Abort *** an exceptio"..., 81*** Abort *** an exception was raised, but no catch was found.
) = 81
write(1, "\33[0m\33[1;31m\t... The exception is"..., 109 ... The exception is:SIGSEGV 'segmentation violation' detected. Address 10
) = 109
write(5, "@", 1) = 1
close(5) = 0
close(4) = 0
rt_sigaction(SIGCHLD, NULL, {0xb577e940, [], SA_SIGINFO|SA_NOCLDSTOP}, 8) = 0
rt_sigaction(SIGCHLD, {SIG_DFL, [], 0}, NULL, 8) = 0
write(1, "\33[0m", 4) = 4
exit_group(1) = ?
+++ exited with 1 +++
yorik
2014-07-09 23:08
administrator   ~0004784
Unfortunately unless you discover a procedure that always causes a crash, that we can reproduce here, there is little we can do. A crash can have many causes, and if we can't reproduce it on other machines, we cannot find what makes it occur.
normandc
2014-07-17 04:32
manager   ~0004806
You have not given details on the exact version you're using (Help --> About FreeCAD --> Copy to clipboard), and how you installed it (Stable PPA? Daily Builds PPA? Compiling?). Otherwise Ubuntu 13.10 end of life is coming this month, I recommend you upgrade to 14.04 LTS and test with this version. On the forum we are quite a few Ubuntu 14.04 users and we have not heard of such a problem.
normandc
2014-07-23 13:19
manager   ~0004837
Saucy Salamander (Ubuntu 13.10) reached end of life on July 17. In my opinion this ticket should be closed.
2014-07-09 18:36 maxiecool2 New Issue
2014-07-09 23:08 yorik Note Added: 0004784
2014-07-17 04:32 normandc Note Added: 0004806
2014-07-23 13:19 normandc Note Added: 0004837
2014-09-22 13:23 shoogen Status new => closed
2014-09-22 13:23 shoogen Resolution open => unable to reproduce
