| 0001619 | FreeCAD | Bug | public | 2014-07-17 03:32 | 2014-07-27 12:32 |
| Reporter | jessefreecad | Assigned To | wmayer | ||
| OS | Windows | OS Version | 7 x64 | ||
| Summary | 0001619: Python script generating 3D model works in V0.13, error in V0.14 | ||||
| Description | The script here: http://forum.freecadweb.org/viewtopic.php?f=22&t=6881 works in freecad V0.13, but in V0.14 at the line: "lcdrect.Placement= App.Placement(App.Vector(5.0,4,pcb_thickness+foambox.Height),App.Rotation(0,0,0,1))" I get this error reported in the python console: Traceback (most recent call last): File "<input>", line 1, in <module> TypeError: First arg must be Quantity | ||||
| Steps To Reproduce | load python script posted into freecad | ||||
| Additional Information | This could easily be a coding error that somehow worked in V0.13 and is now being flagged in V0.14. If so any info on how to fix the script is appreciated. | ||||
Please enquire first on the forum before reporting such problems as a bug. There were changes to the Python Draft API during development of V0.14 to make it compatible with the new units system. I couldn't tell you how to fix your script but I'm pretty sure it's the reason for it not working. A developer will probably confirm. |
To fix the error write: lcdrect.Placement= App.Placement(App.Vector(5.0,4,pcb_thickness+float(foambox.Height)),App.Rotation(0,0,0,1)) Currently the + and - operators do not allow to mix up quantities and floating numbers but for the <,<=,>,>=,!= and == operators we already do (see the linked change set). However, I am unsure whether it's a good idea to support this because it might cause some confusion. Example: l = App.Units.Quantity("1m") d = 5 l + d # this would give "1.005 m" and not "6 m" as some people may expect The point is that the internally stored number of a quantity is ALWAYS given in FreeCAD's standard unit system which is in (mm,kg,s,deg) Btw, the reason why it worked in 0.13 is that the unit system wasn't activated and the appropriate property classes returned real floating numbers and not a quantity. |
I think it's best NOT to allow any mixture of units and floating numbers (for + and - operator) as this can cause many kind of ambiguities. There is now a better error message which gives the script coder a hint what to do. |
FreeCAD: master 8aec46fb 2014-07-14 17:17:41 Details Diff |
+ support comparison with double in quantity number protocol |
Affected Issues 0001619 |
| mod - src/Base/QuantityPyImp.cpp | Diff File | ||
FreeCAD: master a1da4bb4 2014-07-27 14:08:31 Details Diff |
+ fixes 0001619: Python script generating 3D model works in V0.13, error in V0.14 |
| mod - src/Base/Quantity.cpp | Diff File | ||
| 2014-07-17 03:32 | jessefreecad | New Issue | |
| 2014-07-17 04:11 | normandc | Note Added: 0004803 | |
| 2014-07-17 09:04 | wmayer | Changeset attached | => FreeCAD Master master 8aec46fb |
| 2014-07-17 09:27 | wmayer | Note Added: 0004808 | |
| 2014-07-17 09:30 | wmayer | Note Edited: 0004808 | |
| 2014-07-27 12:14 | wmayer | Note Added: 0004859 | |
| 2014-07-27 12:32 | wmayer | Changeset attached | => FreeCAD Master master a1da4bb4 |
| 2014-07-27 12:32 | wmayer | Assigned To | => wmayer |
| 2014-07-27 12:32 | wmayer | Status | new => closed |
| 2014-07-27 12:32 | wmayer | Resolution | open => fixed |
