| 0001621 | Draft | Bug | public | 2014-07-20 03:37 | 2015-03-23 14:44 |
| Reporter | Azureviolin | Assigned To | yorik | ||
| Platform | Intel® Core™ i7-3840QM CPU @ 2.8 | OS | Ubuntu | OS Version | 12.04 |
| Target Version | 0.15 | Fixed in Version | 0.15 | ||
| Summary | 0001621: "Offset" option in "Set/unset a working plane" didn't work | ||||
| Description | what ever I type in the "offset" block, after I click "XY" or "XZ" or "YZ", the working plane always set back to the corresponding working plane without the offset. | ||||
| Steps To Reproduce | launch freecad. choose Draft workbench. click on "set/unset a working plane" type "100" in the box right of "Offset" option click "XY" the working plane is still the XY plane with 0 offset, rather than 100. same can be reproduced with YZ and XZ plane. | ||||
I walked around this problem by using sketcher in Part Design to achieve whatever I want to do. I am a bit confused about the function of Draft and Sketcher, shouldn't there be only one of them? |
This is not the proper place to ask on relevance of FreeCAD workbenches. The wiki already explains this. http://www.freecad.org/wiki/index.php?title=Sketcher_Workbench |
Fixed with resolution of 0001606 |
| 2014-07-20 03:37 | Azureviolin | New Issue | |
| 2014-07-21 03:29 | Azureviolin | Note Added: 0004821 | |
| 2014-07-21 08:38 | shoogen | Priority | high => normal |
| 2014-07-21 08:38 | shoogen | Severity | major => minor |
| 2014-07-23 13:36 | normandc | Note Added: 0004838 | |
| 2014-07-23 13:37 | normandc | Relationship added | duplicate of 0001606 |
| 2014-07-23 22:43 | yorik | Assigned To | => yorik |
| 2014-07-23 22:43 | yorik | Status | new => assigned |
| 2014-08-04 19:36 | yorik | Note Added: 0004920 | |
| 2014-08-04 19:36 | yorik | Status | assigned => closed |
| 2014-08-04 19:36 | yorik | Resolution | open => fixed |
| 2014-08-04 19:36 | yorik | Fixed in Version | => 0.15 |
| 2014-08-08 01:42 | yorik | Target Version | => 0.15 |
| 2015-03-23 14:44 | yorik | Relationship added | has duplicate 0002021 |
