| 0001623 | Sketcher | Feature | public | 2014-07-20 17:47 | 2014-09-28 10:40 |
| Reporter | bejant | Assigned To | abdullah | ||
| Summary | 0001623: Sketcher - Always Display Symmetry Constraint Symbol Perpendicular to Axis of Symmetry | ||||
| Description | When it is used, the Symmetry Constraint symbol always is aligned horizontally, even when the axis of symmetry is skewed or horizontal. This can be confusing when the axis of symmetry is angled, the axis of symmetry is horizontal, or the view is rotated, especially in complicated Sketches. It would be more helpful and meaningful if the Symmetry Constraint symbol was displayed so that its "arrows" always point perpendicularly towards the axis of symmetry, even as the view is rotated. The Horizontal and Vertical Distance Constraint symbols always remain aligned with the line they constrain, even when the view is rotated, and I am asking that the Symmetry Constraint symbol be enhanced in a similar manner. | ||||
| Steps To Reproduce | See attached image: 1. Create a Sketch in the X-Y Plane. 2. Draw a line segment parallel with the Y-axis, straddling the X-axis. 3. Apply the Symmetry Constraint between the endpoints and the Z-axis. 4. Apply a Vertical Distance Constraint to the line segment. The arrowheads of the Symmetry Constraint appear horizontally, which is misleading to the user. 5. Rotate the view about the Z-axis. The Vertical Distance Constraint rotates with the view but the Symmetry Constraint Symbol remains oriented incorrectly (horizontally). | ||||
| Additional Information | Forum topic: http://forum.freecadweb.org/viewtopic.php?f=19&t=6875 OS: Ubuntu 12.04.4 LTS Word size: 32-bit Version: 0.15.3744 (Git) Branch: master Hash: eea27448e995bc87eedaffc3f9153a75291bf9f4 Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.7.0 | ||||
Fixed in current master as of today (will appear in the PPA tomorrow) |
A crash bug seems to be related http://forum.freecadweb.org/viewtopic.php?f=3&t=7820 |
Sebastian, I have just seen this. Which is the status of this? Shall I close this or there is some further action to take... |
I assume that with the fix of Werner for handling the zero division exception, everything works just fine. |
FreeCAD: master 95c512d9 2014-08-23 06:30:48 Committer: wmayer Details Diff |
Sketcher feature enhancement: Symmetry constraint perpendicular to axis of symmetry Solves Mantis ticket: http://www.freecadweb.org/tracker/view.php?id=1623 Unrelated minor fix: remove unused variable |
Affected Issues 0001623 |
| mod - src/Mod/Sketcher/Gui/ViewProviderSketch.h | Diff File | ||
FreeCAD: master f0bf3cb6 2014-09-27 15:53:21 Details Diff |
+ Proper handling of sketch plane parallel to view direction |
| mod - src/Base/Exception.cpp | Diff File | ||
| mod - src/Base/Exception.h | Diff File | ||
| 2014-07-20 17:47 | bejant | New Issue | |
| 2014-07-20 17:47 | bejant | File Added: 20140720a_Mantis.png | |
| 2014-09-02 13:50 | abdullah | Assigned To | => abdullah |
| 2014-09-02 13:50 | abdullah | Status | new => assigned |
| 2014-09-18 13:35 | abdullah | Note Added: 0005123 | |
| 2014-09-18 13:35 | abdullah | Status | assigned => resolved |
| 2014-09-18 13:35 | abdullah | Fixed in Version | => 0.15 |
| 2014-09-18 13:35 | abdullah | Resolution | open => fixed |
| 2014-09-18 16:50 | wmayer | Status | resolved => closed |
| 2014-09-27 08:55 | shoogen | Note Added: 0005156 | |
| 2014-09-27 08:55 | shoogen | Status | closed => feedback |
| 2014-09-27 08:55 | shoogen | Resolution | fixed => reopened |
| 2014-09-27 15:19 | abdullah | Note Added: 0005157 | |
| 2014-09-28 04:56 | abdullah | Note Added: 0005162 | |
| 2014-09-28 04:56 | abdullah | Status | feedback => resolved |
| 2014-09-28 04:56 | abdullah | Resolution | reopened => fixed |
| 2014-09-28 10:31 | wmayer | Changeset attached | => FreeCAD Master master f0bf3cb6 |
| 2014-09-28 10:35 | wmayer | Changeset attached | => FreeCAD Master master 95c512d9 |
| 2014-09-28 10:40 | wmayer | Status | resolved => closed |
