| 0001627 | FreeCAD | Bug | public | 2014-07-22 15:44 | 2014-08-24 09:10 |
| Reporter | obbe | Assigned To | |||
| Platform | 2.26 GHz Intel Core 2 Duo | OS | Macintosh | OS Version | 10.9.3 |
| Summary | 0001627: Dash instead of minus in dialogs/fields | ||||
| Description | Whenever you wish to enter a minus, it does not use minus but a dash. This has the implication that you can not type negative values naturally on a keyboard, but must copy and paste the "minus sign" from a field where it is present. | ||||
| Steps To Reproduce | For example 1. Create a new sketch. 2. Add a line. 3. Add a horizontal vertical distance constraint to the line and make sure its positive. 4. Try setting it to a negative value. | ||||
Might be related to this issue: http://forum.freecad.org/viewtopic.php?f=10&t=7182 |
Seems to be the same. I was also using the Swedish locale. |
Jürgen, please add the alternative minus (\xe2\x88\x92) to the parser. |
fixed with 1da55436578fcf620802ba4e38a0c940723e07e4 needs (swedish) testing.... |
| 2014-07-22 15:44 | obbe | New Issue | |
| 2014-07-30 12:13 | wmayer | Note Added: 0004881 | |
| 2014-07-30 12:24 | obbe | Note Added: 0004882 | |
| 2014-07-30 18:18 | wmayer | Assigned To | => Jriegel |
| 2014-07-30 18:18 | wmayer | Status | new => assigned |
| 2014-07-30 18:19 | wmayer | Note Added: 0004894 | |
| 2014-08-03 17:06 |
Note Added: 0004910 | |
| 2014-08-24 09:10 | wmayer | Changeset attached | => FreeCAD Master master 1b4190b0 |
| 2014-08-24 09:10 | wmayer | Status | assigned => closed |
| 2014-08-24 09:10 | wmayer | Resolution | open => fixed |
| 2014-08-24 09:10 | wmayer | Fixed in Version | => 0.15 |
