| 0001649 | PartDesign | Bug | public | 2014-07-29 21:21 | 2017-01-17 18:13 |
| Reporter | Sterna | Assigned To | |||
| Platform | Macbook Pro late 2011 | OS | OS X | OS Version | 10.9.4 |
| Summary | 0001649: Chaning names on Pads does not change them everywere | ||||
| Description | If I rename an object the new name is not used for any objects referencing this object. The default name is used. For example if you perform a polar pattern feature on a pad, the name that appears in the field "Original feature" is the default name (such as "PadXXX"). This bug leads to confusion, especially for projects with many features. This bug might be part of the Topological naming interface group (Issue 0000876). | ||||
| Steps To Reproduce | Attached a file to show the bug. 1. Select the feature "Toothpad" (original name Pad001). 2. Choose Polar pattern feature. 3. The name in the field "original feature" is "Pad001" instead of "Toothpad". | ||||
| has duplicate | 0002111 | closed | FreeCAD | Dialogs (like linear pattern) should not show internal name of an object but their labels as in the tree view |
You can't rename an Object. You can only change the Label. Maybe we should show the Label in the original field data. (and offer the real name as a tooltip) |
Actually, throughout the GUI the Label should be used. For a normal user the internal name is of no interest. It's only interesting for Python coders and therefore we write the internal name of the object in the status bar when (pre-)selecting it. |
git show c92dbb3 git show 58cb2e2 git show 36b3d33 git show 991d766 git show 9c49a0b |
FreeCAD: master c92dbb32 2016-10-21 15:19:20 Details Diff |
issue 0001649: Changing names on Pads does not change them everywere |
Affected Issues 0001649 |
| mod - src/Mod/PartDesign/Gui/TaskPolarPatternParameters.cpp | Diff File | ||
FreeCAD: master 58cb2e2d 2016-10-21 15:33:43 Details Diff |
| mod - src/Mod/PartDesign/Gui/TaskMirroredParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskTransformedParameters.h | Diff File | ||
FreeCAD: master 36b3d331 2016-10-21 15:38:45 Details Diff |
| mod - src/Mod/PartDesign/Gui/TaskLinearPatternParameters.cpp | Diff File | ||
FreeCAD: master 991d7660 2016-10-21 15:40:26 Details Diff |
| mod - src/Mod/PartDesign/Gui/TaskScaledParameters.cpp | Diff File | ||
FreeCAD: master 9c49a0ba 2016-10-21 15:45:50 Details Diff |
| mod - src/Mod/PartDesign/Gui/TaskMultiTransformParameters.cpp | Diff File | ||
| 2014-07-29 21:21 | Sterna | New Issue | |
| 2014-07-29 21:21 | Sterna | File Added: gearTest2.FCStd | |
| 2014-07-29 21:24 | shoogen | Note Added: 0004874 | |
| 2014-07-30 11:08 | wmayer | Note Added: 0004878 | |
| 2016-10-21 13:47 | wmayer | Note Added: 0007408 | |
| 2016-10-21 13:48 | wmayer | Status | new => closed |
| 2016-10-21 13:48 | wmayer | Resolution | open => fixed |
| 2016-10-21 13:48 | wmayer | Fixed in Version | => 0.17 |
| 2016-10-21 13:50 | wmayer | Changeset attached | => FreeCAD Master master c92dbb32 |
| 2016-10-21 14:00 | wmayer | Changeset attached | => FreeCAD Master master 58cb2e2d |
| 2016-10-21 14:04 | wmayer | Changeset attached | => FreeCAD Master master 36b3d331 |
| 2016-10-21 14:04 | wmayer | Changeset attached | => FreeCAD Master master 991d7660 |
| 2016-10-21 14:08 | wmayer | Changeset attached | => FreeCAD Master master 9c49a0ba |
| 2017-01-17 18:13 | wmayer | Relationship added | has duplicate 0002111 |
