| 0000166 | FreeCAD | Bug | public | 2010-10-08 00:47 | 2011-01-26 12:10 |
| Reporter | yorik | Assigned To | |||
| Summary | 0000166: edges highlight doesn't work anymore | ||||
| Description | I'm not sure if it's the case for everyone, it could be only on my system, but it seems that edge highlighting doesn't work anymore? (Highlighting is turned on, face highlight works OK) Can anyone else check? | ||||
Yes, I also noticed this behaviour some time ago. If you choose another line color than black then it seems to work. |
Indeed you're right... The highlight mechanisms works, but it doesn't respect the colors specified in the preferences, it highlights all edges in black, so if you draw in black you just don't see it. The texts and faces are highlighted with the correct color, though. yorik |
Apparently the issue is partially related to the platform. On 32-bit at least the selection works as expected but not on 64-bit. And the pre-selection doesn't work on any of the platforms. This all is also related to the front buffer we use. If it is disabled everything works normally. |
I changed the preselection color. On Windows release works fine... Hope the color change makes it better on other platforms. Otherwise I run out of ideas. Think the next step is a complete rebuild of the selection. But at the moment I have no time for that.... |
Werner changed the defaults for the 64 bit platform. This at least works - but, as I said, selection need an overhaul.... |
| 2010-10-08 00:47 | yorik | New Issue | |
| 2010-10-11 14:59 | wmayer | Note Added: 0000363 | |
| 2010-10-11 17:19 | unauthenticated | Note Added: 0000364 | |
| 2010-10-11 17:20 | unauthenticated | Note Edited: 0000364 | |
| 2010-10-12 09:33 | wmayer | Assigned To | => Jriegel |
| 2010-10-12 09:33 | wmayer | Status | new => assigned |
| 2010-10-12 11:31 | wmayer | Note Added: 0000372 | |
| 2011-01-13 08:34 |
Note Added: 0000509 | |
| 2011-01-13 08:34 |
Status | assigned => feedback |
| 2011-01-26 12:10 |
Note Added: 0000554 | |
| 2011-01-26 12:10 |
Status | feedback => closed |
| 2011-01-26 12:10 |
Resolution | open => fixed |
| 2011-01-26 12:10 |
Fixed in Version | => 0.11 |
