| 0001660 | Draft | Bug | public | 2014-08-01 14:17 | 2014-08-08 01:43 |
| Reporter | microelly2 | Assigned To | yorik | ||
| Target Version | 0.15 | Fixed in Version | 0.15 | ||
| Summary | 0001660: Draft.scale should use default value = 1 for scaling | ||||
| Description | When you scale an object using the mouse only the values x,y are changed z maps to zero after finishing the scale operation the resulting clone has a scale.z = 0 and becomes invisible | ||||
| 2014-08-01 14:17 | microelly2 | New Issue | |
| 2014-08-01 14:20 | yorik | Assigned To | => yorik |
| 2014-08-01 14:20 | yorik | Status | new => assigned |
| 2014-08-04 15:32 | yorik | Changeset attached | => FreeCAD Master master e41996c9 |
| 2014-08-04 15:32 | yorik | Status | assigned => closed |
| 2014-08-04 15:32 | yorik | Resolution | open => fixed |
| 2014-08-08 01:42 | yorik | Target Version | => 0.15 |
| 2014-08-08 01:43 | yorik | Fixed in Version | => 0.15 |
