| 0001661 | Draft | Bug | public | 2014-08-01 17:26 | 2014-08-08 01:43 |
| Reporter | microelly2 | Assigned To | yorik | ||
| Platform | ubuntu 14 | ||||
| Target Version | 0.15 | Fixed in Version | 0.15 | ||
| Summary | 0001661: Draft Convert Sketch to Draft | ||||
| Description | I convert a Sketch back to a Draft object the draft object (dwire, circle) is created the sketch is deleted an additional object "Block" is created with no extra functionality the Block should be deleted the sketch shold be preserved - so I can use it when constraints change found at freecad 0.15.3737 | ||||
| 2014-08-01 17:26 | microelly2 | New Issue | |
| 2014-08-01 19:39 | yorik | Note Added: 0004907 | |
| 2014-08-01 19:39 | yorik | Assigned To | => yorik |
| 2014-08-01 19:39 | yorik | Status | new => assigned |
| 2014-08-04 16:02 | yorik | Changeset attached | => FreeCAD Master master a601434c |
| 2014-08-04 16:02 | yorik | Status | assigned => closed |
| 2014-08-04 16:02 | yorik | Resolution | open => fixed |
| 2014-08-08 01:42 | yorik | Target Version | => 0.15 |
| 2014-08-08 01:43 | yorik | Fixed in Version | => 0.15 |
