| 0001664 | Draft | Bug | public | 2014-08-02 19:00 | 2015-01-04 22:59 |
| Priority | low | Severity | trivial | Reproducibility | always |
| Platform | Kubuntu 14.04 | ||||
| Summary | 0001664: Draft rotate in yz-plane asks for angle in "mm" | ||||
| Description | Draft rotate in yz-plane asks for angle in "mm" | ||||
| Steps To Reproduce | 1. Select yz-plane as working plane for draft 2. Select a part 3. Choose rotate 4. Set base coordinates to 0,0,0 5. Rotate asks for base angle in "mm" | ||||
| Additional Information | OS: Ubuntu 14.04.1 LTS Word size: 64-bit Version: 0.14.3702 (Git) Branch: releases/FreeCAD-0-14 Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 | ||||
Are you sure?? For me it shows "deg" correctly... Anyone else can test this? |
I attached a screenshot. The mm is only shown until I start moving the mouse, then ° is shown as it should. |
I also have this behavior on another computer with FreeCAD under Windows. OS: Windows XP Word size: 32-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 |
Ah ok I see... Indeed the field is initialized on "mm" and changes after you move the mouse. I'll fix that. |
Hi Yorik, wmayer fixed bug 0001848 which reverted this change, apparently causing problems when the UI asks for a radius. Can you take another look? Michael |
FreeCAD: master 0f559a71 2014-09-18 16:18:15 Details Diff |
Draft: Fixed rotation UI unit - fixes 0001664 |
Affected Issues 0001664 |
| mod - src/Mod/Draft/DraftGui.py | Diff File | ||
FreeCAD: master 9ee08a97 2015-01-04 23:38:47 Details Diff |
Draft: fixed 0001664 again |
| mod - src/Mod/Arch/ArchFloor.py | Diff File | ||
| mod - src/Mod/Draft/DraftTools.py | Diff File | ||
| 2014-08-02 19:00 | mghansen256 | New Issue | |
| 2014-08-08 01:29 | yorik | Note Added: 0004926 | |
| 2014-08-08 01:30 | yorik | Assigned To | => yorik |
| 2014-08-08 01:30 | yorik | Status | new => feedback |
| 2014-08-08 08:00 | mghansen256 | Note Added: 0004927 | |
| 2014-08-08 08:00 | mghansen256 | Status | feedback => assigned |
| 2014-08-08 08:01 | mghansen256 | File Added: 2014-08-08-freecad-rotation-mm.png | |
| 2014-08-08 08:03 | mghansen256 | File Added: 2014-08-09-freecad-rotation-mm-really.png | |
| 2014-08-08 08:06 | mghansen256 | Note Added: 0004928 | |
| 2014-08-09 15:01 | yorik | Note Added: 0004932 | |
| 2014-09-18 14:40 | yorik | Changeset attached | => FreeCAD Master master 0f559a71 |
| 2014-09-18 14:40 | yorik | Status | assigned => closed |
| 2014-09-18 14:40 | yorik | Resolution | open => fixed |
| 2015-01-04 19:49 | mghansen256 | Note Added: 0005514 | |
| 2015-01-04 19:49 | mghansen256 | Status | closed => feedback |
| 2015-01-04 19:49 | mghansen256 | Resolution | fixed => reopened |
| 2015-01-04 22:59 | yorik | Changeset attached | => FreeCAD Master master 9ee08a97 |
| 2015-01-04 22:59 | yorik | Status | feedback => closed |
