| 0001669 | FreeCAD | Bug | public | 2014-08-07 20:31 | 2015-01-07 10:19 |
| Reporter | mghansen256 | Assigned To | wmayer | ||
| Platform | Linux | OS | Kubuntu | OS Version | 14.04 |
| Summary | 0001669: Part operation with parts in groups splits again when moved back into group | ||||
| Description | When doing a cut between a part in a group and a part not in a group, the part which was originally in the group is shown as a child of the group when the cut is moved back into the group after the cut. Not sure how to describe it better, better try to reproduce it as shown below. The same is also true for union operations. | ||||
| Steps To Reproduce | 1. Create a cube 2. Create a sphere 3. Create a group "test", add cube to it 4. Ctrl-select first cube, then sphere 5. Do Part-cut. Cube and sphere are children of the cut, and the cut is not in the group. 6. Move the cut back into group "test" Result: group test contains cube set to invisible, and the cut with just the sphere as the child Expected: Group test should contain the cut with cube and sphere being children of the cut | ||||
| Additional Information | OS: Ubuntu 14.04.1 LTS Word size: 64-bit Version: 0.14.3702 (Git) Branch: releases/FreeCAD-0-14 Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 | ||||
| Tags | tree view | ||||
The following behaviour could be a manifestation of the same bug. If you think it's a different, please tell me, I could open a new bug report. Steps to reproduce. 1) Start a new part document 2) Create a cube, a sphere and a group 3) Move sphere and cube into group 4) Select sphere and cube and make a cut between them 5) Actual result: The new Cut object is outside the group (and the sphere and cube are children of the Cut object) Expected result: The new Cut object would be inside the group 6) Move the Cut object back into the group 7) Actual result: The cube, the sphere and the Cut are direct children of the group object Expected result: The cut object is the child of the group, and the cube and the sphere are the children of the Cut object. |
| 2014-08-07 20:31 | mghansen256 | New Issue | |
| 2014-09-06 21:28 | intherye | Note Added: 0005078 | |
| 2014-09-07 10:25 | shoogen | Tag Attached: tree view | |
| 2014-09-07 10:28 | shoogen | Severity | minor => tweak |
| 2015-01-07 10:19 | wmayer | Changeset attached | => FreeCAD Master master be2e1916 |
| 2015-01-07 10:19 | wmayer | Assigned To | => wmayer |
| 2015-01-07 10:19 | wmayer | Status | new => closed |
| 2015-01-07 10:19 | wmayer | Resolution | open => fixed |
