| 0001677 | Draft | Feature | public | 2014-08-08 18:59 | 2015-01-11 18:10 |
| Platform | Linux | OS | Kubuntu | OS Version | 14.04 |
| Summary | 0001677: Draft dimensions: automatic extension line lengths | ||||
| Description | When adding a draft dimension, the extension lines are always only as long as specified in the preferences. IMHO a good extra option would be to extend the lines automatically up to the point to which they refer. | ||||
| Additional Information | OS: Ubuntu 14.04.1 LTS Word size: 64-bit Version: 0.15.3844 (Git) Branch: master Hash: 28490532f50135e2490f94cdf401b613a94b1ec2 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 | ||||
You just need to set the lenght to zero IIRC |
Yes, that works. Would be cool to have that info in the preferences dialog somehow, maybe a checkbox "Auto length", which enables the length setting when unchecked? |
To have Auto Length you can just set 0.0 to extension size in the preferences ? It could be cool to add a check-box to choose if the extension line size is calculate from the dimension object or the dimensioned object. Example : the dimension line is placed 50 mm from the dimensioned line. I set the extension size to 20 mm. If the check-box is checked the extension size is 50-20 = 30 mm. |
Ah yes, same as autocad... Yes we could do that... |
| 2014-08-08 18:59 | mghansen256 | New Issue | |
| 2014-08-08 22:05 | yorik | Note Added: 0004931 | |
| 2014-08-09 19:47 | mghansen256 | Note Added: 0004934 | |
| 2015-01-04 13:34 | rockn | Note Added: 0005503 | |
| 2015-01-04 17:12 | yorik | Note Added: 0005508 | |
| 2015-01-04 17:12 | yorik | Assigned To | => yorik |
| 2015-01-04 17:12 | yorik | Status | new => assigned |
| 2015-01-11 18:10 | yorik | Changeset attached | => FreeCAD Master master 74856e5f |
| 2015-01-11 18:10 | yorik | Status | assigned => closed |
| 2015-01-11 18:10 | yorik | Resolution | open => fixed |
