| 0001694 | FreeCAD | Bug | public | 2014-08-16 22:33 | 2014-08-28 19:12 |
| Reporter | Simon.pasquet | Assigned To | yorik | ||
| OS | Ubuntu | OS Version | 14.04.1 LTS | ||
| Summary | 0001694: customizing multiple keys shortcut doesn't work | ||||
| Description | When you try to customize shortcuts with several keys in it, the second key erase the first. It might be a bug because, wall in Arch s'workbench has the "wa" shortcut. | ||||
| Steps To Reproduce | Go to tool>customize>keyboard and press keys on "new shortcut" | ||||
| Additional Information | the function responsible of this is: AccelLineEdit::keyPressEvent() in ./src/Gui/Widgets.cpp the setText(tr("none")) line 372 erase the previous key. OS: Ubuntu 14.04.1 LTS Word size: 64-bit Version: 0.15.3881 (Git) Branch: master Hash: 7665e34a3a844dc0e21aa86375ff9de1e632ec36 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 | ||||
Indeed this dialgo has never been upgraded to use two-letters shortcuts. I'll have a look at how to do that (probably cycle through one letter -> two letters -> one letter etc...) |
Reading your post at http://forum.freecadweb.org/viewtopic.php?f=10&t=7367&p=59678 , if you want to work on this, feel free to do it! |
There is a patch to fix the bug. I used: $git format-patch master --stdout > multipleKeysShortcuts.patch I don't know if it's the right way to do it, nor the right place to post it. |
Ok, looks cool! I'll test it |
| 2014-08-16 22:33 | Simon.pasquet | New Issue | |
| 2014-08-17 02:11 | yorik | Note Added: 0004957 | |
| 2014-08-17 02:11 | yorik | Assigned To | => yorik |
| 2014-08-17 02:11 | yorik | Status | new => assigned |
| 2014-08-17 15:50 | yorik | Note Added: 0004958 | |
| 2014-08-17 15:50 | yorik | Note Edited: 0004958 | |
| 2014-08-24 21:16 | Simon.pasquet | File Added: multipleKeysShortcuts.patch | |
| 2014-08-24 21:26 | Simon.pasquet | Note Added: 0005003 | |
| 2014-08-24 22:48 | yorik | Note Added: 0005004 | |
| 2014-08-28 19:12 | yorik | Changeset attached | => FreeCAD Master master 55cf9dde |
| 2014-08-28 19:12 | yorik | Status | assigned => closed |
| 2014-08-28 19:12 | yorik | Resolution | open => fixed |
| 2014-08-28 19:12 | yorik | Fixed in Version | => 0.15 |
