| 0001701 | FreeCAD | Feature | public | 2014-08-19 13:42 | 2017-04-28 17:47 |
| Reporter | shoogen | Assigned To | |||
| Priority | normal | Severity | major | Reproducibility | N/A |
| Summary | 0001701: do not catch BaseException, Exception, StandardError or Warning | ||||
| Description | Catch statements should be as specific as possible. Catching "all" Exceptions must be avoided. The current behavior has enormous drawbacks when it comes to interaction with outside python modules. | ||||
| Additional Information | this might not be feasible for Pivy | ||||
| Tags | exception | ||||
ed66ada1cfd5d5763d64c0346cb988137c44a6d5 2014-09-17 d$ grep -r -E "except\w*(:|Exception)" src/Mod/ |cut -d "/" -f 3 |sort |uniq -c |sort -rn 106 Draft 49 Arch 31 Ship 15 OpenSCAD 13 Spreadsheet 9 Test 4 Plot 4 PartDesign 4 Import 1 Start 1 Sketcher 1 Robot 1 Part 1 Material 1 Fem src/App/FreeCADInit.py (after execfile) |
$ grep -r -E "catch\w* \(\.\.\.\)" src/Mod/ |cut -d "/" -f 3 |sort |uniq -c |sort -rn 33 Part 8 Mesh 3 PartDesign 2 Sketcher 1 Web 1 Raytracing 1 Points 1 Fem 1 Cam |
grep -r -E "catch\w* \(\.\.\.\)" src/$1 |wc -l 5 Base 12 App 29 Gui |
a way to uncover the type of exceptions is to add a print clause import FreeCAD,traceback try: pass except: FreeCAD.Console.PrintWarning(traceback.format_exc()) |
FreeCAD: master 57db95a1 2014-08-24 19:48:23 Details Diff |
issue 0001701 removed further except: statements |
Affected Issues 0001701 |
| mod - src/App/FreeCADInit.py | Diff File | ||
| mod - src/Mod/Material/importFCMat.py | Diff File | ||
| mod - src/Mod/Part/MakeBottle.py | Diff File | ||
| mod - src/Mod/Sketcher/InitGui.py | Diff File | ||
FreeCAD: master e820a326 2014-09-18 12:55:35 Committer: yorik Details Diff |
issue 0001701 |
| mod - src/Mod/Arch/ArchCommands.py | Diff File | ||
| mod - src/Mod/Arch/ArchComponent.py | Diff File | ||
| mod - src/Mod/Arch/ArchEquipment.py | Diff File | ||
| mod - src/Mod/Arch/ArchRebar.py | Diff File | ||
| mod - src/Mod/Arch/ArchSectionPlane.py | Diff File | ||
| mod - src/Mod/Arch/ArchSpace.py | Diff File | ||
| mod - src/Mod/Arch/ArchStructure.py | Diff File | ||
| mod - src/Mod/Arch/ArchVRM.py | Diff File | ||
| mod - src/Mod/Arch/ArchWindow.py | Diff File | ||
| mod - src/Mod/Arch/importDAE.py | Diff File | ||
| mod - src/Mod/Arch/importIFClegacy.py | Diff File | ||
| mod - src/Mod/Draft/DraftGui.py | Diff File | ||
| mod - src/Mod/Draft/DraftTrackers.py | Diff File | ||
| mod - src/Mod/Fem/CalculixLib.py | Diff File | ||
| mod - src/Mod/Import/InitGui.py | Diff File | ||
| mod - src/Mod/PartDesign/InitGui.py | Diff File | ||
| mod - src/Mod/PartDesign/Scripts/Gear.py | Diff File | ||
| mod - src/Mod/Ship/shipHydrostatics/Tools.py | Diff File | ||
| mod - src/Mod/Spreadsheet/Spreadsheet.py | Diff File | ||
FreeCAD: master 1673ab80 2017-04-28 16:49:11 Details Diff |
use specialized exception classes |
| mod - src/App/Document.cpp | Diff File | ||
| mod - src/App/DocumentObject.cpp | Diff File | ||
| mod - src/App/DocumentPyImp.cpp | Diff File | ||
| mod - src/App/DynamicProperty.cpp | Diff File | ||
| mod - src/App/Expression.cpp | Diff File | ||
| mod - src/App/ExpressionParser.l | Diff File | ||
| mod - src/App/Extension.cpp | Diff File | ||
| mod - src/App/ExtensionContainer.cpp | Diff File | ||
| mod - src/App/FeatureTest.cpp | Diff File | ||
| mod - src/App/GeoFeatureGroupExtension.cpp | Diff File | ||
| mod - src/App/ObjectIdentifier.cpp | Diff File | ||
| mod - src/App/Origin.cpp | Diff File | ||
| mod - src/App/OriginGroupExtension.cpp | Diff File | ||
| mod - src/App/Property.cpp | Diff File | ||
| mod - src/App/PropertyExpressionEngine.cpp | Diff File | ||
| mod - src/App/PropertyFile.cpp | Diff File | ||
| mod - src/App/PropertyLinks.cpp | Diff File | ||
| mod - src/App/PropertyStandard.cpp | Diff File | ||
| mod - src/App/PropertyUnits.cpp | Diff File | ||
| mod - src/App/Range.cpp | Diff File | ||
| mod - src/App/lex.ExpressionParser.c | Diff File | ||
| mod - src/Base/Builder3D.cpp | Diff File | ||
| mod - src/Base/CoordinateSystem.cpp | Diff File | ||
| mod - src/Base/Exception.cpp | Diff File | ||
| mod - src/Base/Exception.h | Diff File | ||
| mod - src/Base/Interpreter.cpp | Diff File | ||
| mod - src/Base/Parameter.cpp | Diff File | ||
| mod - src/Base/PyObjectBase.h | Diff File | ||
| mod - src/Base/Quantity.cpp | Diff File | ||
| mod - src/Base/Reader.cpp | Diff File | ||
| mod - src/Base/Unit.cpp | Diff File | ||
| mod - src/Base/UnitsApi.cpp | Diff File | ||
| mod - src/Base/Writer.cpp | Diff File | ||
| mod - src/Base/XMLTools.h | Diff File | ||
| mod - src/Base/swigpyrun.inl | Diff File | ||
| mod - src/Gui/Command.cpp | Diff File | ||
| mod - src/Gui/DlgExpressionInput.cpp | Diff File | ||
| mod - src/Gui/ExpressionBinding.cpp | Diff File | ||
| mod - src/Gui/ManualAlignment.cpp | Diff File | ||
| mod - src/Gui/PythonConsole.cpp | Diff File | ||
| mod - src/Gui/SelectionFilter.cpp | Diff File | ||
| mod - src/Gui/SoFCOffscreenRenderer.cpp | Diff File | ||
| mod - src/Gui/SoTouchEvents.cpp | Diff File | ||
| mod - src/Gui/View3DInventor.cpp | Diff File | ||
| mod - src/Gui/View3DInventorViewer.cpp | Diff File | ||
| mod - src/Gui/ViewProvider.cpp | Diff File | ||
| mod - src/Gui/ViewProviderExtern.cpp | Diff File | ||
| mod - src/Gui/ViewProviderOriginGroupExtension.cpp | Diff File | ||
| mod - src/Gui/WidgetFactory.cpp | Diff File | ||
| mod - src/Gui/WinNativeGestureRecognizers.cpp | Diff File | ||
| mod - src/Gui/WorkbenchManager.cpp | Diff File | ||
| mod - src/Mod/Image/App/ImageBase.cpp | Diff File | ||
| mod - src/Mod/Mesh/App/Core/MeshKernel.cpp | Diff File | ||
| mod - src/Mod/Mesh/App/Core/Triangulation.cpp | Diff File | ||
| mod - src/Mod/Mesh/App/FeatureMeshSetOperations.cpp | Diff File | ||
| mod - src/Mod/Mesh/App/Mesh.cpp | Diff File | ||
| mod - src/Mod/Points/App/PointsAlgos.cpp | Diff File | ||
| mod - src/Mod/Sandbox/App/DocumentProtector.cpp | Diff File | ||
| 2014-08-19 13:42 | shoogen | New Issue | |
| 2014-08-19 13:42 | shoogen | Relationship added | parent of 0001700 |
| 2014-09-15 17:24 | shoogen | Tag Attached: exception | |
| 2014-09-17 11:13 | shoogen | Note Added: 0005112 | |
| 2014-09-17 11:15 | shoogen | Summary | do not catch BaseException, Exception, StandardError or Warnig => do not catch BaseException, Exception, StandardError or Warning |
| 2014-09-17 11:15 | shoogen | Description Updated | |
| 2014-09-17 11:18 | shoogen | Note Added: 0005113 | |
| 2014-09-17 11:21 | shoogen | Note Added: 0005114 | |
| 2014-09-17 11:24 | shoogen | Note Edited: 0005113 | |
| 2014-09-17 11:40 | shoogen | Changeset attached | => FreeCAD Master master 57db95a1 |
| 2014-09-21 09:48 | shoogen | Note Added: 0005142 | |
| 2014-09-27 16:30 | yorik | Changeset attached | => FreeCAD Master master e820a326 |
| 2017-04-28 16:53 | wmayer | Changeset attached | => FreeCAD master 1673ab80 |
| 2017-04-28 17:47 | wmayer | Status | new => closed |
| 2017-04-28 17:47 | wmayer | Resolution | open => won't fix |
