| 0000171 | FreeCAD | Bug | public | 2010-10-08 13:03 | 2010-12-15 11:55 |
| Summary | 0000171: Unify Draft keyboard shortcuts | ||||
| Description | The draft module uses a lot of hardcoded shortcuts, that should either depend on the localization (using "&" in the texts) or be customizable via the freecad customize screen | ||||
This is now basically done, all actions in the Draft module that are not FreeCAD commands but anyway would need a keyboard shortcut now have 3 levels of customization: - a builtin "hard-coded" shortcut - an ALT-shortcut defined in the widget label, that can be changed by translators - a proper FreeCAD shortcut, defined by the FreeCAD customize menu. I didn't totally remove the hardcoded shortcuts, because some qt widgets really steal all keypresses without modifier key, but I think with two alternatives this is not too bad. |
| 2010-10-08 13:03 | yorik | New Issue | |
| 2010-10-08 13:03 | yorik | Status | new => assigned |
| 2010-10-08 13:03 | yorik | Assigned To | => yorik |
| 2010-12-15 11:55 | yorik | Note Added: 0000453 | |
| 2010-12-15 11:55 | yorik | Status | assigned => closed |
| 2010-12-15 11:55 | yorik | Resolution | open => fixed |
| 2010-12-15 11:55 | yorik | Fixed in Version | => 0.11 |
