| 0001713 | Sketcher | Feature | public | 2014-08-26 05:47 | 2014-08-26 11:42 |
| Reporter | ickby | Assigned To | wmayer | ||
| Platform | Windows | OS | Windows | OS Version | 7 |
| Summary | 0001713: Allow Part.Arc to be used as Sketcher geometry | ||||
| Description | currently Part.ArcOfCircle is used to add circular arcs to the sketcher. As the part workbench also provides the Arc geometry type it should be posible to use it also. If not at least a message should apear that it is not supported. Currently the geometrie counter increases when Part.Arc is added but nothing is displayed. OS: Windows 7 Word size: 64-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.6.0 | ||||
| Steps To Reproduce | >>> App.ActiveDocument.Sketch.addGeometry(Part.Arc(App.Vector(33.0,66.5,0.3),App.Vector(32.85857864376269,66.44142135623731,0.3),App.Vector(32.8,66.3,0.3))) 0 >>> App.ActiveDocument.Sketch.addGeometry(Part.Arc(App.Vector(33.0,66.5,0.3),App.Vector(32.85857864376269,66.44142135623731,0.3),App.Vector(32.8,66.3,0.3))) 1 >>> App.ActiveDocument.Sketch.addGeometry(Part.Arc(App.Vector(33.0,66.5,0.3),App.Vector(32.85857864376269,66.44142135623731,0.3),App.Vector(32.8,66.3,0.3))) 2 | ||||
Theoretically it works to check in Sketch::addGeometry whether the underlying curve of "GeomTrimmedCurve" is a circle and temporarily create a GeomArcOfCircle and add it to the sketch. However, it appears that there is much more to do than this: the ViewProvider needs special adjustments (otherwise you get a recursive traversal error from Coin), you need to handle with the icon, all I/O methods of GeomTrimmedCurve must be implemented, ... And since it's preferred to use GeomArcOfCircle I simply handle the use of GeomTrimmedCurve inside SketchObjectPy::addGeometry and convert a GeomTrimmedCurve to GeomArcOfCircle. And there is also a check to add only supported geometries and raise an exception for all other types. |
| 2014-08-26 05:47 | ickby | New Issue | |
| 2014-08-26 07:16 | ickby | OS | all => Windows |
| 2014-08-26 07:16 | ickby | OS Version | all => 7 |
| 2014-08-26 07:16 | ickby | Platform | all => Windows |
| 2014-08-26 07:16 | ickby | Description Updated | |
| 2014-08-26 07:16 | ickby | Steps to Reproduce Updated | |
| 2014-08-26 11:24 | wmayer | Note Added: 0005012 | |
| 2014-08-26 11:42 | wmayer | Changeset attached | => FreeCAD Master master d974d689 |
| 2014-08-26 11:42 | wmayer | Assigned To | => wmayer |
| 2014-08-26 11:42 | wmayer | Status | new => closed |
| 2014-08-26 11:42 | wmayer | Resolution | open => fixed |
