| 0001721 | FreeCAD | Bug | public | 2014-08-31 18:41 | 2015-01-06 18:00 |
| Reporter | normandc | Assigned To | wmayer | ||
| Summary | 0001721: PartDesign Pad "Up to face" face selection in the 3D view not working | ||||
| Description | When padding a sketch on top of an existing solid using the "Up to face" option, face selection is not possible in the 3D view. When hovering the mouse pointer, presection highlighting is off, and selection is off. The only way to force face selection is to delete the "No face selected" text in the text field besides the "Face" button, and manually type in the face name then type Enter. The Pad parameters then close, and the newly created pad is hidden. Toggling its visibility back shows the operation worked, and if we edit the Pad, the face selection now works. | ||||
| Steps To Reproduce | 1. Open provided "UpToFace_bug_normandc1.fcstd" file 2. Delete Pad001 3. Select Sketch001 4. Click on the Pad icon 5. Change type to "Up to face" 6. Click on the "Face" button 7. Face selection in the 3D view is inoperative. 8. Enter "Face1" in the text field 9. Press Enter 10. Pad001 is created but hidden from view. | ||||
| Additional Information | Forum topic: http://forum.freecadweb.org/viewtopic.php?f=3&t=7527#p61217 Tested on both current stable release and development branch (master). OS: Ubuntu 14.04.1 LTS Word size: 64-bit Version: 0.14.3702 (Git) Branch: releases/FreeCAD-0-14 Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 OS: Ubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.3969 (Git) Branch: master Hash: 80e80fef832d6b9582e5f9fb77c0c1b4f2532111 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 | ||||
Additional info: PartDesign Pocket is unaffected by this bug. |
I made a test model with several steps, so there are several faces from which to select, here in the above topic that may be useful for testing. http://forum.freecadweb.org/viewtopic.php?f=3&t=7527&p=61293#p61293 Another thing I noticed when editing the existing Pad, in pad to face mode, if you select a face first then click "Face" button it ignores the face you had already selected you then have to click on a face again and then it works. There is also a selection issue from within Part Shape Builder, where Box selection does not work. I assume these are not related so I will create a differnt bug report. |
| 2014-08-31 18:41 | normandc | New Issue | |
| 2014-08-31 18:41 | normandc | File Added: UpToFace_bug_normandc1.fcstd | |
| 2014-08-31 18:44 | normandc | Note Added: 0005036 | |
| 2014-09-01 08:00 | jmaustpc | Note Added: 0005050 | |
| 2015-01-06 18:00 | wmayer | Changeset attached | => FreeCAD Master master 010fc6f3 |
| 2015-01-06 18:00 | wmayer | Assigned To | => wmayer |
| 2015-01-06 18:00 | wmayer | Status | new => closed |
| 2015-01-06 18:00 | wmayer | Resolution | open => fixed |
