| 0001722 | FreeCAD | Bug | public | 2014-08-31 20:12 | 2014-11-06 13:41 |
| Reporter | nahshon | Assigned To | yorik | ||
| Platform | Linux | OS | Fedora | OS Version | 19 |
| Summary | 0001722: Left-handed helix with an angle>0 produces 1 too many turns | ||||
| Description | Left-handed helix with an angle>0 produces 1 too many turns. Looks OK for right-handed helix or with angle == 0. For long helix (height/pitch > 50) the problem is only in the first part where there are two turn instead of one. Also (GUI) negative angles are ignored therefore better be disabled. | ||||
| Steps To Reproduce | Select "Create Primitives..." from the Part menu. Select "Helix" Select values (I use Height=100mm, Pitch=100mm, Radius=50mm". Select an angle > 0. Select "Left-handed" Click "Create" A helix with two turns is created (should be 1). | ||||
| Additional Information | OS: "Fedora release 20 (Heisenbug)" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.3966 (Git) Branch: master Hash: 67b54f805203271d95ffa6f07912bbc196ff2078 Python version: 2.7.5 Qt version: 4.8.6 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.7.1 Possibly related to issue 0000124 | ||||
