| 0001725 | Draft | Feature | public | 2014-09-01 14:16 | 2014-09-15 20:00 |
| Reporter | quick61 | Assigned To | yorik | ||
| Summary | 0001725: Add option in ShapeString dialog to allow use of single line fonts (stick fonts) | ||||
| Description | Currently, Draft > ShapeString will not allow the use of single line True Type Fonts like those found here - http://www.mrrace.com/CamBam_Fonts/ When invoking ShapeString, an error occurs from not being able to create a face. | ||||
| Steps To Reproduce | Download Stick Font zip file from http://www.mrrace.com/CamBam_Fonts/ Unzip fonts and attempt to use one of the nine stick fonts in a ShapeString. | ||||
| Additional Information | Reference Forum Thread - http://forum.freecadweb.org/viewtopic.php?f=8&t=7542 | ||||
Will add this asap! |
Just built and tested http://sourceforge.net/p/free-cad/code/ci/a723ec4b81ac666b418ac315182a96cc7392884a/ I am getting the error - Traceback (most recent call last): File "/home/mark/Build/FreeCAD/Mod/Draft/Draft.py", line 4903, in execute s = self.makeFaces(char) File "/home/mark/Build/FreeCAD/Mod/Draft/Draft.py", line 4952, in makeFaces face.validate() <type 'exceptions.Exception'>: - with most stick fonts in the CamBam pack. Font 9, while not producing an error in report view, does not display correctly. See attached. |
Yes I'm still not happy with it either. there are more problems, some lines mising, etc. |
FreeCAD: master a723ec4b 2014-09-04 20:57:59 Details Diff |
Draft: Allow sticky fonts in ShapeString |
Affected Issues 0001725 |
FreeCAD: master 9af4df3c 2014-09-10 20:56:50 Details Diff |
Draft: minor fix in Shapestring |
FreeCAD: master 4b59ef15 2014-09-15 21:43:14 Details Diff |
Draft: fixed sticky fonts - fixes 0001725 |
| 2014-09-01 14:16 | quick61 | New Issue | |
| 2014-09-01 14:35 | yorik | Assigned To | => yorik |
| 2014-09-01 14:35 | yorik | Status | new => assigned |
| 2014-09-01 14:35 | yorik | Note Added: 0005052 | |
| 2014-09-04 19:58 | quick61 | File Added: CamBam_StickFont_9.fcstd | |
| 2014-09-04 19:58 | quick61 | Note Added: 0005071 | |
| 2014-09-04 19:59 | quick61 | Note Edited: 0005071 | |
| 2014-09-04 20:22 | yorik | Note Added: 0005072 | |
| 2014-09-04 20:22 | yorik | Changeset attached | => FreeCAD Master master a723ec4b |
| 2014-09-11 00:24 | yorik | Project | FreeCAD => Draft |
| 2014-09-11 00:24 | yorik | Changeset attached | => FreeCAD Master master 9af4df3c |
| 2014-09-15 20:00 | yorik | Changeset attached | => FreeCAD Master master 4b59ef15 |
| 2014-09-15 20:00 | yorik | Status | assigned => closed |
| 2014-09-15 20:00 | yorik | Resolution | open => fixed |
