| 0001729 | PartDesign | Feature | public | 2014-09-03 11:34 | 2014-09-20 17:57 |
| Reporter | sjoerd | Assigned To | normandc | ||
| Platform | linux | OS | archlinux | OS Version | running |
| Summary | 0001729: tree view representation of pads and pockets is counter intuitive | ||||
| Description | I've been using freecad for a while now. I think it is great but there is something I don't get. When you pad a sketch the Pad object includes the original shape; that's logical since you'd want the original surface to be removed in the places where the padding touches the support surface. But what I don't get is that the original object is a sibling of the new Pad object in the object tree; I would really expect it to be a child just like the sketch that was padded... This may be a deliberate design choice but in that case the behaviour needs some explaining in the documentation because I cannot think of a reason why it is this way or why anyone would want it this way... | ||||
| Steps To Reproduce | create some object select a surface create a sketch on that surface pad or pocket the sketch observe the object tree | ||||
one more clarification: this is a problem since any project with a complexity level above 'very simple' tends to have a very cluttered object tree. I often mistakenly attach sketches to surfaces of 'inner' objects for instance. |
Please do not use the bug tracker to voice your opinions or critics on how FreeCAD works. You should first discuss this on the FreeCAD forum. http://forum.freecadweb.org/viewforum.php?f=8 As it is, this "bug" report is invalid. |
This is not a valid bug report but should have been posted on the forum instead. |
| 2014-09-03 11:34 | sjoerd | New Issue | |
| 2014-09-03 13:42 | sjoerd | Note Added: 0005063 | |
| 2014-09-20 17:55 | normandc | Note Added: 0005137 | |
| 2014-09-20 17:57 | normandc | Note Added: 0005138 | |
| 2014-09-20 17:57 | normandc | Status | new => closed |
| 2014-09-20 17:57 | normandc | Assigned To | => normandc |
| 2014-09-20 17:57 | normandc | Resolution | open => no change required |
