| 0000173 | FreeCAD | Bug | public | 2010-10-12 08:19 | 2010-10-13 09:33 |
| Reporter | midgetfc | Assigned To | wmayer | ||
| Summary | 0000173: a few text files in svn don't have the proper mime-type | ||||
| Description | src/WindowsInstaller/CMakeLists.txt src/Build/CMakeLists.txt cMake/FindWix.cmake cMake/FreeCadMacros.cmake have svn:mime-type property set to application/octet-stream This precludes their insertion in the patches generated with svn diff in case they are modified, as they are treated as binary files. It is of course a minor inconvenience, but easy to fix. Fix: delete the property (svn propdel svn:mime-type <target>) I also checked the source files having executable flag set. Nothing to bother with, but for the sake of cleanliness... I can send you the list (42 files) Cheers Midgetfc | ||||
Fixed in 3623. Yes, tell me the list of executable cpp files |
Here it is. The other executables are a few scripts (sems OK), and some .py python files for which I have no idea if it's correct. src/App/DocumentObjectGroup.cpp src/App/DocumentObjectGroup.h src/Base/Rotation.cpp src/Base/Rotation.h src/Gui/DlgMaterialProperties.ui src/Gui/DlgMaterialPropertiesImp.cpp src/Gui/DlgMaterialPropertiesImp.h src/Gui/DlgProjectInformation.ui src/Gui/DlgProjectInformationImp.cpp src/Gui/DlgProjectInformationImp.h src/Gui/SoFcInteractiveElement.cpp src/Gui/SoFcInteractiveElement.h src/Gui/SplitView3DInventor.cpp src/Gui/SplitView3DInventor.h src/Gui/ViewProviderDocumentObjectGroup.cpp src/Gui/ViewProviderDocumentObjectGroup.h src/Mod/Image/Gui/Resources/translations/Image_de.ts src/Mod/Mesh/App/FeatureMeshSolid.cpp src/Mod/Mesh/App/FeatureMeshSolid.h src/Mod/Mesh/Gui/DlgRegularSolid.ui src/Mod/Mesh/Gui/DlgRegularSolidImp.cpp src/Mod/Mesh/Gui/DlgRegularSolidImp.h src/Mod/Mesh/Gui/SoFCMeshFaceSet.cpp src/Mod/Mesh/Gui/SoFCMeshFaceSet.h src/Mod/Mesh/Gui/SoFCMeshVertex.cpp src/Mod/Mesh/Gui/SoFCMeshVertex.h src/Mod/Mesh/Gui/ViewProviderMeshFaceSet.cpp src/Mod/Mesh/Gui/ViewProviderMeshFaceSet.h src/Mod/Mesh/Gui/ViewProviderMeshNode.cpp src/Mod/Mesh/Gui/ViewProviderMeshNode.h src/Mod/Mesh/Gui/Resources/translations/Mesh_de.ts src/Mod/Points/Gui/Resources/translations/Points_de.ts src/Mod/Test/Gui/AppTestGui.cpp src/Mod/Test/Gui/Makefile.am src/Mod/Test/Gui/PreCompiled.cpp src/Mod/Test/Gui/PreCompiled.h src/Mod/Test/Gui/UnitTest.ui src/Mod/Test/Gui/UnitTestImp.cpp src/Mod/Test/Gui/UnitTestImp.h src/Mod/Test/Gui/UnitTestPy.cpp src/Mod/Test/Gui/UnitTestPy.h src/Mod/Test/Gui/Resources/translations/Test_de.ts Cheers Midgetfc |
Fixed in 3626. Thanks. |
| 2010-10-12 08:19 | midgetfc | New Issue | |
| 2010-10-12 09:39 | wmayer | Note Added: 0000370 | |
| 2010-10-12 09:40 | wmayer | Assigned To | => wmayer |
| 2010-10-12 09:40 | wmayer | Status | new => assigned |
| 2010-10-12 14:53 | midgetfc | Note Added: 0000373 | |
| 2010-10-13 09:33 | wmayer | Note Added: 0000374 | |
| 2010-10-13 09:33 | wmayer | Status | assigned => closed |
| 2010-10-13 09:33 | wmayer | Resolution | open => fixed |
