| 0001732 | Arch | Bug | public | 2014-09-05 12:20 | 2014-09-18 13:41 |
| Reporter | Goofy03 | Assigned To | yorik | ||
| Platform | PC | OS | ArchLinux | OS Version | Latest |
| Summary | 0001732: Windows and wall with negative height | ||||
| Description | If you set negative height to a wall then add a windows, every time you save and reopen document, the negative value is added to the z axis. I get same problem if you set a negative z value to a floor object. | ||||
| 2014-09-05 12:20 | Goofy03 | New Issue | |
| 2014-09-05 14:43 | yorik | Relationship added | child of 0001597 |
| 2014-09-05 14:44 | yorik | Assigned To | => yorik |
| 2014-09-05 14:44 | yorik | Status | new => assigned |
| 2014-09-05 14:44 | yorik | Note Added: 0005075 | |
| 2014-09-18 13:41 | yorik | Note Added: 0005125 | |
| 2014-09-18 13:41 | yorik | Status | assigned => closed |
| 2014-09-18 13:41 | yorik | Resolution | open => fixed |
| 2014-09-18 13:41 | yorik | Fixed in Version | => 0.15 |
