| 0001735 | FreeCAD | Bug | public | 2014-09-06 11:09 | 2014-10-17 21:21 |
| Reporter | jr222 | Assigned To | wmayer | ||
| Platform | PC | OS | Windows 7 64x | OS Version | 6.1.7601 |
| Summary | 0001735: Ellipsoids visibility problems | ||||
| Description | Ellipsoids (created via Part>Primitives>Create Primitive...) do not recolor to yellow when selected. The appearance / "Display Properties" of the ellipsoids cannot be changed either using the Right-Click on the object name + Appearance (Display Properties window). | ||||
| Steps To Reproduce | Part 1 1. Create an ellipsoid using created via Part>Primitives>Create Primitive..., press the "Create" button... it is fine to just make the default ellipsoid 2. Select it using the mouse pointer 3. Expected result would be to see it change color when selected Part 2 4. Select the ellipsoid in the tree within the combo view 5. Right click the ellipsoid 6. Select "Appearance" from the menu 7. Change color, transparency, anything, and it won't work | ||||
| Additional Information | I am running the newest 64x version of Freecad. Here is the copy and paste of the "About Freecad" window, if it may help: OS: Windows 7 Word size: 64-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.6.0 | ||||
I confirm this on FreeCAD version and platform below. In fact, the ellipsoid object is not selectable at all in the 3D view. OS: Ubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4052 (Git) Branch: master Hash: 6561b99347a53fab1fbc5b480690826f70bc06e9 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.1 |
how about using the generic viewprovider diff --git a/src/Mod/Part/Gui/ViewProvider.cpp b/src/Mod/Part/Gui/ViewProvider.c pp index bf7acf3..96a5f8b 100644 --- a/src/Mod/Part/Gui/ViewProvider.cpp +++ b/src/Mod/Part/Gui/ViewProvider.cpp @@ -1165,21 +1165,6 @@ void ViewProviderEllipsoid::updateData(const App::Propert y* prop) if (cShape.IsNull()) return; App::DocumentObject* object = this->getObject(); - if (object && object->isDerivedFrom(Part::Ellipsoid::getClassTypeId())) { - double angle1 = static_cast<Part::Ellipsoid*>(object)->Angle1.getVa lue(); - double angle2 = static_cast<Part::Ellipsoid*>(object)->Angle2.getVa lue(); - double angle3 = static_cast<Part::Ellipsoid*>(object)->Angle3.getVa lue(); - float radius1 = static_cast<Part::Ellipsoid*>(object)->Radius1.getV alue(); - float radius2 = static_cast<Part::Ellipsoid*>(object)->Radius2.getV alue(); - if (angle1 == -90.0 && angle2 == 90.0 && angle3 == 360.0) { - float scale = radius1/radius2; - pScaling->scaleFactor.setValue(1,1,scale); - pSphere->radius.setValue(radius2); - FaceRoot->addChild(pScaling); - FaceRoot->addChild(pSphere); - return; // ok, done - } - } // if not a full ellipsoid do it the general way ViewProviderPartBase::updateData(prop); |
The reason for having a special view provider was because of some tessellation problems of OCC at that time. Maybe things work better now and we can switch back to the generic one. |
git show dd392ef |
FreeCAD: master dd392efe 2014-10-16 19:36:54 Details Diff |
+ fixes 0001735: Ellipsoids visibility problems |
Affected Issues 0001735 |
| mod - src/Mod/Part/Gui/ViewProvider.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/ViewProvider.h | Diff File | ||
| mod - src/Mod/Part/Gui/ViewProviderSphereParametric.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/ViewProviderSphereParametric.h | Diff File | ||
| 2014-09-06 11:09 | jr222 | New Issue | |
| 2014-09-20 17:50 | normandc | Note Added: 0005136 | |
| 2014-09-20 18:09 | shoogen | Note Added: 0005139 | |
| 2014-09-20 19:04 | wmayer | Note Added: 0005140 | |
| 2014-10-17 11:55 | wmayer | Note Added: 0005225 | |
| 2014-10-17 11:55 | wmayer | Status | new => closed |
| 2014-10-17 11:55 | wmayer | Assigned To | => wmayer |
| 2014-10-17 11:55 | wmayer | Resolution | open => fixed |
| 2014-10-17 11:55 | wmayer | Fixed in Version | => 0.15 |
| 2014-10-17 21:21 | wmayer | Changeset attached | => FreeCAD Master master dd392efe |
