| 0001736 | FreeCAD | Bug | public | 2014-09-09 09:21 | 2014-12-04 14:01 |
| Reporter | Thierry | Assigned To | wmayer | ||
| Platform | Fujitsu-Siemens Pentium | OS | Windows XP | OS Version | XP Pro SP3 |
| Summary | 0001736: Parts with multiple colors are displayed in a single bad color after hiding | ||||
| Description | In the design process or for variants management, I need to hide parts (Hide selection) and save and close the design. When I open the design again and need to see some of the hidden parts (Show selection), the parts are displayed in a single color which was the default color set in the preferences pane at the time they were saved. To have the parts in their original colors again, I must have them visible, save the file, close the file, and open the file. The parts should always display with the right colors, whether they have been saved hidden or visible. | ||||
| Steps To Reproduce | - create a simple solid part, cube or cylinder - make faces different colors - select and hide the part - save the file - close the file - open the file - select and show the part : single color, default color to make it visible again : - make the part visible - save the file - close the file - open the file : the part has its original colors again | ||||
| Additional Information | More details here : http://forum.freecadweb.org/viewtopic.php?f=3&t=7591 | ||||
| Tags | GUI | ||||
Might be related. Changes to view properties (I tested with color and transparency) are not undoable/redoable. Also the document is not marked as changed ("*") after view property changes. If a shape is deleted, undoing the delete returns the shape with the default (not the previously assigned) view properties. |
I confirm : To definitely loose colors : select a part, delete it, then undo. The part takes the default color, I found not way back. Applies both on single and multi colored parts. |
| 2014-09-09 09:21 | Thierry | New Issue | |
| 2014-09-09 11:50 | shoogen | Tag Attached: GUI | |
| 2014-09-09 13:22 | wmayer | Status | new => confirmed |
| 2014-09-16 16:35 | nahshon | Note Added: 0005107 | |
| 2014-09-22 11:47 | Thierry | Note Added: 0005144 | |
| 2014-09-22 11:49 | Thierry | Note Edited: 0005144 | |
| 2014-12-04 14:01 | wmayer | Changeset attached | => FreeCAD Master master 6872b2c3 |
| 2014-12-04 14:01 | wmayer | Assigned To | => wmayer |
| 2014-12-04 14:01 | wmayer | Status | confirmed => closed |
| 2014-12-04 14:01 | wmayer | Resolution | open => fixed |
