| 0001737 | FreeCAD | Feature | public | 2014-09-09 18:32 | 2014-09-30 22:15 |
| Reporter | bejant | Assigned To | yorik | ||
| Summary | 0001737: Add GUI ability to search in the FreeCAD document. | ||||
| Description | As users are creating increasingly complicated models with FreeCAD the ability to search by using an alphanumeric text string would be useful. | ||||
| Additional Information | From the following forum thread: http://forum.freecadweb.org/viewtopic.php?f=3&t=7577 | ||||
The way I see it: - Use the Selection window, because it already does most of the job - Add a search box on top of it - As the contents of the search box changes, display below (select) all the objects which label or name matches the search box contents Other improvements to the selection window - Add the label to the selection items, for ex: Unnamed.Line001.Edge1 (MyLine) - Allow to double-click an item in the list to select only that item - Add a context menu to the items with a couple of options such as deselect, select only (same as double-click), zoom in 3D view and zoom in tree view I'll attribute this to myself, but if anyone else is interested in working on this, feel free to reassign to yourself! |
FreeCAD: master ce0f2452 2014-09-13 17:02:45 Details Diff |
Mis upgrades for the selection window - fixes 0001737 * Added a search box that searches through object labels * Added a context menu to selected items * Allow to double-click an item to isolate |
Affected Issues 0001737 |
| add - src/Gui/Icons/edit-cleartext.svg | Diff File | ||
| mod - src/Gui/Icons/resource.qrc | Diff File | ||
| add - src/Gui/Icons/view-select.svg | Diff File | ||
| mod - src/Gui/Icons/view-unselectable.svg | Diff File | ||
| mod - src/Gui/SelectionView.cpp | Diff File | ||
| mod - src/Gui/SelectionView.h | Diff File | ||
| 2014-09-09 18:32 | bejant | New Issue | |
| 2014-09-09 19:02 | yorik | Note Added: 0005082 | |
| 2014-09-09 19:03 | yorik | Assigned To | => yorik |
| 2014-09-09 19:03 | yorik | Status | new => assigned |
| 2014-09-13 15:30 | yorik | Changeset attached | => FreeCAD Master master ce0f2452 |
| 2014-09-13 15:30 | yorik | Status | assigned => closed |
| 2014-09-13 15:30 | yorik | Resolution | open => fixed |
| 2014-09-30 22:15 | yorik | Relationship added | has duplicate 0001770 |
