| 0001754 | FreeCAD | Feature | public | 2014-09-18 16:05 | 2015-01-09 15:39 |
| Reporter | hughsient | Assigned To | yorik | ||
| Priority | low | Severity | feature | Reproducibility | always |
| Platform | Linux | ||||
| Summary | 0001754: Please install the supplied AppData file | ||||
| Description | Please consider installing this AppData file: https://raw.githubusercontent.com/hughsie/fedora-appstream/master/appdata-extra/desktop/freecad.appdata.xml This is used in GNOME and KDE software installers to add the application description and some screenshots. We'd love to showcase more applications, but without the extra data file we can't. The AppData file needs to be installed to /usr/share/appdata/ on Linux and the basename needs to match the .desktop basename. It would also be great if you could integrate the file with your translation system (e.g. intltool) to make the descriptions translated. See http://people.freedesktop.org/~hughsient/appdata/ for more details; thanks! Richard | ||||
I already made such file too: https://github.com/FreeCAD/FreeCAD_sf_master/blob/master/package/debian/freecad.appdata.xml Just not sure how/where it must be installed *EDIT* ah I should have read your description better |
Hi, your AppData file does not validate and can't be used: /usr/share/appdata/freecad.appdata.xml license 'LGPL' invalid You really should use a SPDX ID from this list: http://people.freedesktop.org/~hughsient/appdata/#metadata_license -- if you *have* to use LGPL, you need to specify the version and use a http://spdx.org/licenses/ SPDX identifier. Thanks! |
| 2014-09-18 16:05 | hughsient | New Issue | |
| 2014-09-18 16:50 | yorik | Note Added: 0005128 | |
| 2014-09-18 16:51 | yorik | Note Edited: 0005128 | |
| 2015-01-09 12:29 | hughsient | Note Added: 0005603 | |
| 2015-01-09 15:39 | yorik | Changeset attached | => FreeCAD Master master fa12868d |
| 2015-01-09 15:39 | yorik | Assigned To | => yorik |
| 2015-01-09 15:39 | yorik | Status | new => closed |
| 2015-01-09 15:39 | yorik | Resolution | open => fixed |
