| 0001755 | FreeCAD | Bug | public | 2014-09-18 17:58 | 2014-09-19 18:44 |
| Reporter | shoogen | Assigned To | yorik | ||
| Summary | 0001755: Avoid using unicode as names in parameter system | ||||
| Description | currently paramters names are automatically translated resulting in invalid user.csg and system.csg files. http://forum.freecadweb.org/viewtopic.php?f=10&t=5464&start=20#p44255 "The parameter system was not designed to take Names in UTF8, only Values! I think Parameter names should only be English and ASCII, the translation is done in the dialogues which are designed to manipulate the parameter." (Jürgen on 2014-01-06) http://forum.freecadweb.org/viewtopic.php?f=10&t=5464 http://forum.freecadweb.org/viewtopic.php?f=3&t=7203 http://forum.freecadweb.org/viewtopic.php?f=3&t=7725 | ||||
| Tags | translation, unicode, XML | ||||
please review the fix at git://github.com/5263/FreeCAD.git toolbar-translation https://github.com/5263/FreeCAD/compare/toolbar-translation |
Merged, thanks for the fix! |
FreeCAD: master e5429731 2014-09-19 10:16:48 Committer: yorik Details Diff |
fixes 0001755: don't translate toolbar names in InitGui.py of Arch and Spreadsheet |
Affected Issues 0001755 |
| mod - src/Mod/Arch/InitGui.py | Diff File | ||
| mod - src/Mod/Spreadsheet/InitGui.py | Diff File | ||
FreeCAD: master 810fadab 2014-09-19 18:13:34 Details Diff |
Fixed bug introduced by last commit |
| 2014-09-18 17:58 | shoogen | New Issue | |
| 2014-09-18 17:58 | shoogen | Relationship added | related to 0001614 |
| 2014-09-18 17:59 | shoogen | Tag Attached: unicode | |
| 2014-09-18 17:59 | shoogen | Tag Attached: XML | |
| 2014-09-18 18:04 | shoogen | Summary | Avoid using unicode in parameter system => Avoid using unicode as names in parameter system |
| 2014-09-19 08:19 | shoogen | Note Added: 0005130 | |
| 2014-09-19 08:19 | shoogen | Assigned To | => yorik |
| 2014-09-19 08:19 | shoogen | Status | new => assigned |
| 2014-09-19 08:19 | shoogen | Tag Attached: translation | |
| 2014-09-19 13:37 | yorik | Note Added: 0005133 | |
| 2014-09-19 13:50 | yorik | Changeset attached | => FreeCAD Master master e5429731 |
| 2014-09-19 13:50 | yorik | Status | assigned => closed |
| 2014-09-19 13:50 | yorik | Resolution | open => fixed |
| 2014-09-19 18:44 | shoogen | Changeset attached | => FreeCAD Master master 810fadab |
